SL/R230: Valve Train Noise?
2003 MB SL500
Valve Train Noise?
Hi all,
Long time lurker, first time poster here.
Just bought a 2003 SL500 w/ 17,000 miles. Under light acceleration between 1500 to 2000 RPM, I'm getting a noise that sounds like a valve train flutter. There is a light ticking sound that accompanies this.
I was told by an MB road test technician that it might be a carbon build up. I was advised to use a detergent gasoline, such as Chevron for a couple of tanks. In addition, I also used a fuel system additive that claims to clean fuel injectors and remove carbon build-up in the heads and valves.
None of the above has made any difference. My question is... is this sound normal? If not, is this a problem anyone else has experienced?
Thanks!
Thanks!
CLS63, GLK350
Hi all,
Thanks!
Thanks!
2003 MB SL500
Yes, I bought a 12 month Starmark warranty. The car was a CPO from Naples MB. I *thought* a CPO car would have to pass an inspection before being sold, but apparently not.
I searched MBWorld before posting my question and there was one thread that sounded similar to my own scenario. It turned out to be a faulty catalytic converter.
Although the noise sounds like it's valve train related, I can't say for sure. Anybody want to venture a guess on what this could be?
SL55AMG, Ferrari 348, Ferrari Testarossa, Ferrari F40, Ferrari Mondial t, Ducati 916, Indycar
XSNSX, I have seen this on a friends' SL as well. He was told the same from the dealer. I have personally been in his car ad can add this: after you accelerate hard for a couple of moments, the noise is gone. It sure had me scratching my head and all I can come up with is it probably is due to oil pressure issue.
2003 MB SL500
The replies are greatly appreciated guys. The car is being returned to the dealer this week. I'll post the results of their inspection for future reference.
Again, I can't say it's the valve train, but it has a ticking noise noise that is directly relevant to the RPM's between 1500-2000. One more thing... first thing in the morning, when the engine is cold and for the first mile, there is no noise... just the sweet sound of a smooth, well balanced motor. As the engine warms up, this "fluttering & ticking" sound becomes noticeable. Again, only under light acceleration between 1500-2000 RPMs.
I'd like to say it's my imagination, but passengers have commented on the sound w/o my solicitation.
1 Post
06' E55, 10' Harley Davidson F-250 6.4L TT
My CLS55 has the same noise. When it's cold it sounds good but as soon as I go for a drive and stop somewhere the sound is present. I also notice it when I go to a drive through and stop at drive through window I here that cling sound coming from the engine. And i'm pretty easy on my engine. Ive had it since 65 miles it now as 10,000. My freinds s55 doesnt do it and he has 46000 miles.
2003 MB SL500
Thanks for chiming in. Nice to know I'm not alone. I thought if others experienced the same, it would be easier to diagnose, or at least share the collective knowledge of forum members with the service technician, hopefully saving him time, but more likely... educating him when he can't figure it out on his own! ![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
Please accept my apologies for NOT being up to speed on the CLS55, but does it share the same "basic" motor with the SL500?
Thanks again all!
Thanks again all!
SL500 2003 Designo (sold), SL500 2004, Nissan GT350
I have a 2003 SL500. I get the same ticking noise at low speed. Almost sounds like a deisel engine or a bad valve. It goes away after a while. I figured this was normal. I am interested in what the dealer says
2003 MB SL500
I'll post the diagnoses as soon as I know more...
Thanks again everyone!
2003 MB SL500
I'm told by the service techs these engines are not particularly quiet motors. I'm also told the SL engines are loose tolerance because they are all aluminum, prone to more expanding and contracting then an iron block or heads, hence... more noise. (not sure I'm buying this!)
Anyhow... my problem is fixed. I have smooth running and QUIET car again.
PS: Also had the clips on the brake calipers replaced because the car was squealing constantly, or until the brakes were applied.
