SL/R230: FS: 2007 SL600 wheels, 18", staggered, mint!
300D, 500E, E420
I have a set of four wheels from a 2007 SL600. They are in excellent condition, they were only on the car for approx 400 miles, then removed. All four wheels with center caps are included. I do NOT have the lug bolts, and tires are NOT included - sorry. The wheels are straight and clean, but have minor surface scratches in the clear coat on the wheels, most are only visible close up. Click this link for lots of detailed photos. Here are the specs:
Front wheels:
8.5J x 18, ET35
Part # A230-401-22-02, MSRP $570 each
Factory tire size 255-40-18
Rear wheels:
9.5J x 18, ET40
Part # A230-401-23-02, MSRP $595 each
Factory tire size 285-35-18
$800 for the set, plus shipping. Free local pickup or delivery in the Boise, Idaho area.
![Cool](https://mbworld.org/forums/images/smilies/cool.gif)
All four wheels:
![](http://www.w124performance.com/misc/R230_wheels/set_frontview.jpg)
MB stock photo of SL600 with these wheels:
![](http://www.w124performance.com/misc/R230_wheels/SL600.jpg)
Front wheel, shown mounted on my car:
![](http://www.w124performance.com/misc/R230_wheels/on_car2.jpg)
Rear wheel, shown mounted on my car:
Front wheels:
8.5J x 18, ET35
Rear wheels:
9.5J x 18, ET40
All four wheels:
![](http://www.w124performance.com/misc/R230_wheels/on_car1.jpg)
300D, 500E, E420
No, sorry... I don't own the SL600 that they came off (or any SL, actually). I bought the wheels for my car, but the offset isn't right on a 124. The guy who owned the SL600 put on something expensive like Brabus or Carlsson... can't remember exactly. No photos of those, though.
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
Advertise more locally, b/c they are used, Id probably buy them myself if you lived within 30 minutes, then if one's bent you'ld be easy to find.
If you ever head out eastward throw them in the trunk coz if they're perfectly true luv to have them.
300D, 500E, E420
ANyway to determine what other hotrods might fit? The're a sort of traditional style (sim famous Cragers), so should attract someone.
Best wishes!
Bytheway, it appears that the offset is different than base SL, that could be part of the problem.
Best wishes!
300D, 500E, E420
The offset will vary based on wheel width... since these are wider than the older SL's, the offset number will be different. But will should bolt up to any R230, and probably all R129's as well. Any car with the same bolt pattern, and enough room for the width/offset, can use them... but I have NO idea what non-Mercedes apps would be!
