SL/R230: Here we go with that darned DST and the clock again!
I must disagree with them, this is the second time my clock didn't update on it's own, I had to do it manually, again.
Reading the manual it clearly says that you can only use the automatic feature IF THE CAR KNOWS WHEN THE TIME CHANGE IS TO OCCUR.
Use the manual setting if the car doesn't know.
Both of these are diametrically opposed to what the dealer tells me. It would be great if it would work by itself but it won't, and to my mind it needs a software update to tell it when the new times are to occur. It may set itself on a minute by minute basis from the GPS sats but it sure won't change a whole 60 minutes!
The car is an '03 SL 500 with COMAND and NAV.
I know there have been many posts on this topic some reference an MB site that has info on setting the clock but I can't find anything when I go there. I KNOW how to set it, I'd just like it to work the way the dealer 'thinks' it should.
Thanks for reading my rant!
J Tinsby
The day on which DST takes effect was recently changed, and the software needs updating. Responsible computer and software manufacturers provided patches or updates for this. I'm surprised (and disappointed) that MB hasn't.
It's not a big deal to set it manually but geez on a car that cost $100k+ where's the "service after the sale part?"
Part of the problems with stealerships is that they are so used to dealing with pablum puking old farts who take what they say as gospel. The have no reason to question what the dealer says because they have no experience to draw from, they just pay the bill without b****ing and go home!
This is the sort of thing that irritates knowledgeable owners. It's a small thing I know but it's the small things that matter more likely than not in the long run.
Regards,
J Tinsby
You don't say if the car has NAV, but that would surely be effected too if there were no satellite signals going to the head unit.
Do you have the NAV and does it work as it should?
Beyond that I'm at a loss to advise you what to look for next.
Good luck with it!
J Tinsby
Sure I know you don't have tin foil all over the dash but there are some sun protectors that lay on the dash to cut glare and so on. One of them might have a metallic core you can't see. If the receiver antennas are in the dash this might be something to consider.
Cheers,
J Tinsby
There is no connection ( no pun intended ) between the clock keeping time and the date on the disc. Any disc should work no matter what.
J Tinsby
I decided to ask a friend from NASA about it.
Here is the response from Dr. TS Kelso who runs the Celestrak web page: www.celestrak.com when I asked him about the GPS satellites and our clocks.
"GPS satellites actually keep GPS Time, which is a fixed offset from International Atomic Time. As such, the receiver must account for the rules such as Daylight Savings Time for each time zone. For example, in Windows, each time zone has the rules of whether DST is observed, when it starts, when it ends, how much it shifts, and so on. When the rules change, the software in Windows must be changed.
So, the short answer is that MB needs to reprogram their clocks to recognize the new rules if they are getting their time from GPS."..... Dr. TS Kelso
Which is exactly what we all suspected but I wouldn't hold my breath waiting for that update to come!
Thanks to the Dr. for his answer!J Tinsby
