SL/R230: ASAP! Buying Rims. Size verify.
Dear colleagues,
I considered to be some rims for my SL at last.
And I have a very nice offer from dealer.
But all rims are 20x8.5 5/112 ET35
What do you about those ones? will they fit on SL?
What are your suggestions on tires?
It's ASAP, please make your comments.
Thanks.
Thanks.
Recommended 20' guidelines for SL
20x8.5
Offset: 32mm
Bolt Pattern: 5-112
Rec. Tire Size: 245/35-20
REAR
20x9.5
Offset: 34mm
Bolt Pattern: 5-112
Rec. Tire Size: 275/30-20
20x8.5
Offset: 32mm
Bolt Pattern: 5-112
REAR
20x9.5
Offset: 34mm
Bolt Pattern: 5-112
And if finally i choose those rims, what size of tire should I use on the rear rims? The same as with 9.5?
Thanks.
20x9.5 9(Rim size).
I have to figure out something... I guess those things (don't know how to say in english), let's say separators, which make rim to look wider, are not good to use?
Also, I have some issues that if I put 255/35 and 275/30, there is no chance of lowering later, right? Because I read here on forums, that lots of people have troubles with bolts or smth... Anyways, in Lithuania, all are total losers and don't know how to lower SL... Damn!
To lower your car, you can simply click 'ABC' and lower your car w/ 20' and it will look pretty nice. if you want to further lower professionally , you can get the RennTech lowering module. do a search on the forum, many have done that. It's a matter of personal taste and willing to pay for such optionals.
btw..seperators called 'spacers' here.
- That I am not sure about. I would check w/ specialized wheel shop or tuner if u can find one in your area. Or maybe do a search on the forum.
good luck.
amer
good luck.
amer
Well, I just bought those rims from the shop: 20x8.5 ET35.
Also, took spacers, which fit perfectlly, but I'm a lil bit confused of using them. Dealer says that it's ok...
Now, thinking about tires, what size to use.
It's a big problem with them, read somewhere that the best choice would be 255/30R20 for all 4 wheels.
Thanks for your opinion.
Artyi.
Artyi.
By the way... "ABC" is pressed when is it with "red" light?
I have never used this one, coz never knew what it is doing, shame one me..
SL55 AMG
good luck.
amer
good luck.
amer
