SL/R230: Concerns after test drive of SL500
1. Hard to get into and out of. Does wheel pull away and/or seat go back when key is pulled out?
2. Hard ride. I commute into NY City. Will the 18" wheels give me too hard a ride? How do the 17" wheels handle?
3. Heating/Air Conditioning controls. Can you direct air to different vents (foot vs. dash) and control fan speed? Is it hard to do when driving?
4. Seat width. I have a broad back and standard seat seemed narrow. I was hitting the bolsters on each side. Are the ventilated seats wider?
5. Controls for radio, navigation and heating seem hard to use. I commute and need a driver friendly car. Will I be too frustrated?
Thanks. I love the car and have only a few weeks to decide whether to order.
Can order SL500 for delivery in March, BUT had some concerns after test ride. (Loved the car and want to see if I can address concerns.) Can you help?
Yes, this is a user setable option.
The 18" wheels will ride rougher, however, I am not sure how much so over a 17".
Yes, fully adjustable if you take it out of AUTO mode. Once you learn the system it's a no brainer.
Seats are about the same width.
Again, easy to use once you learn the layout and controls.
awiner has almost answered ur questions but i'll throw in my opinon's as well
i think the ABC should soak up a lot of the small bumps.. not sure.. the 17's we have are awesome on those continental tires
the air stuff is really easy even when you are driving.. my dad does it all the time
i think thye only difference in seats is the holes in the seats.. for the air to pass thru..
also i think if you get the massager you can change the bolsters..
its very very easy to get used to when u drive. i went from lexus to honda to benz and its all embbeded in my mind.
My SL55 roof makes no noises, there are no shakes or rattles and some of our roads are no better than those in NYC. If your MB dealer cannot fix the roof, the solution is to change dealer, not the car.
john1960, if you are concerned with ride quality, the SL has a more sporting character than the S class and that does mean a harder ride. If you want a completely isolating ride, the S class will be better. Either that, or vote in a politician who will have the courage to raise more in taxes to tackle the crumbling infra-structure.
As for the seats, the purpose of the bolsters is to provide lateral support as the car goes round corners. I find them very comfortable indeed, more so than any of my other cars and they are not as extreme as the sport seats you'll find in a 911.
A: No question, the getting in and out is a bit more difficult than for a sedan. We also have the '03 E500 and it, as a sedan, is a bit easier. But, if you want more of a sports car than a sedan, they will ride lower and you will have that with any make. But, there is a setting to make the seat go back and steering wheel raise upon entry and exit.
A: We have the launch edition wheels that are 19". The ride is adjustable and it is very smooth. I doubt you will have a problem. The wheelbase is shorter than a sedan of course and for that reason, you will notice certain road conditions a little more. Again, it is a function of the sports car rather than sedan.
A: This is absolutely no problem. The rings on the outside of the controls manage that.
A: On our SL with the Drive Dynamic seats, the bolster width is adjustable. Perhaps the one you sat in was set narrow. Having said that, again, this is a sports car with solid support intended to keep you in place. The seats are more "narrow" than on our E500 without the Drive Dynamic Seats
A: While not "easy" to learn, they are very functional and after a few times of use, I find them great. I especially like the function of our voice activated V60 phone system. Very safe to use with little more than pulling back the phone activation stalk on the right side of the steering column and speaking whatever command you want the phone to do, i.e., "dial number" and then speak the number, etc.
On balance, I see your decision as being whether you want a sports car or a sedan. For us, the decision was "both". So, we got the new SL and the new E. For commuting, I would probably choose the new E as it is a little more comfortable.
