SL/R230: NEED HELP ASAP!!! Will sl55 mufflers fit on a sl500?
Old Sep 1, 2008 | 07:32 PM
SL55AMGSTER's Avatar
cls 63, e55, sl amg
Exclamation NEED HELP ASAP!!! Will sl55 mufflers fit on a sl500?
Will a sl55 amg muffler fit on a sl500, i know that the rear bumper will not fit the tips without modification, but will they fit on the car or will i have like spare tire clearance issues?
thanks alot!!!!!!
Old Sep 3, 2008 | 01:17 AM
cls 63, e55, sl amg
BUMP
Old Sep 3, 2008 | 03:57 AM
Murtaza's Avatar
C63S coupe, X5M
If you have a 500, why is your name SL55AMGSTER?
To answer your question, yes they will fit.
Old Sep 3, 2008 | 09:57 AM
cls 63, e55, sl amg
My username is SL55AMGSTER because i had made my username along time ago. at the time i was going to purchase a sl55 and that fell through and i ended up getting a sl500.
Thanks for the info on the mufflers fitting. you dont think i will have any clearance issues under the car? Have you seen this done before?
Old Sep 3, 2008 | 01:45 PM
Murtaza's Avatar
C63S coupe, X5M
I haven't seen it done but I've heard of it being done a bunch of times. If anything the SL55 mufflers are smaller then the 500's...
Old Sep 3, 2008 | 03:31 PM
cls 63, e55, sl amg
do you think that my car would sound any different. Louder? or is the sl55 louder due to other reasons?
Old Sep 3, 2008 | 07:12 PM
Murtaza's Avatar
C63S coupe, X5M
Sound doesn't come from the mufflers, it comes from the detonations inside the engine. Everything behind the headers only alter that base exhaust note.
That said I do believe the 55 mufflers do not muffle sound as much as the 500 mufflers, so it's likely to be louder.
Old Sep 3, 2008 | 07:47 PM
Dragoncoach's Avatar
2004 SL500R / 2003 BMW M5
I think I read a thread awhile ago mentioning a problem with the fitment of the quad pipes as opposed to the regular duals on the 500. Better check it out before you jump in and buy the exhaust.
Old Sep 8, 2008 | 04:48 AM
UKSilverArrow's Avatar
SL500 R230
I've done it, no fitment problems under the car, brackets and hangers in the same places you just need to open up the bumper. The AMG back box is a straight through design with perforatted pipe and wadding as opposed to a baffle system in the standard 500.
You can choose to fit the extra resonators for the AMG (there's space) or not. I did but did away with the 500's merge pipe (very restrictive) to separate the left and right exhaust flows which gives a more trditional V8 sound.
David
Old Sep 8, 2008 | 11:25 AM
Sorry. You mentioned what I was referring to. Modification or cutting of the bumper is necessary when fitting an SL55 exhaust on an SL500. Thanks for clarification!
Old Sep 8, 2008 | 04:56 PM
SL500 R230
Maybe I misunderstood your post, although I as well as the original poster understood it was fairly obvious that the bumper would need cutting to fit the AMG quad pipes as it's been pointed out may times before.
I beleive he is referring to the under car fitment and differing pipe sizes which concerned me when contemplating this mod.
David
