SL/R230: How to setup a garage opener?
Does anyone know how to setup the garage opener below the mid-mirrow?
press one mirror button and at the same time point your car remote at it and release once LEDs flash rapidly.
These are hard things to set up as most garage doors now use a rolling code
That said, if you have a rolling code garage door opener:
Push both outside buttons to clear codes.
Push the "learn" button on your garage door opener (you'll need the manual for that).
Push and hold the button you want to program until blinking on opener and mirror stops.
I've never had much luck using the remote to program the mirror remote.
If that doesn't work, try searching the forums or try a google search.
Hope this helps.
The trick is to point your remote at the forward facing side of the mirror.
), then you can set it up correctly.
http://www4.mercedes-benz.com/e/cars...d13e24673.html
I had sorts of grief because my 2004 SL didn't have the new frequencies of the garage openers. Got a convertor from Homelink which works side-by-side with the one in the garage so can use all frequencies.
[/URL]Create Animated GIFs With GIFSoup.com[/url]
Last edited by ChrisBranum; Oct 3, 2009 at 01:02 PM. Reason: Image was not working
http://www.mbusa.com/mercedes/owners...007c184335RCRD
[/URL]http://www.gifsoup.com"]Create Animated GIFs With GIFSoup.com
The problem seems to be that my garage door remote is 430 MHz, and my SL550 is equipped with code 232 - GARAGE DOOR OPENER WITH 284 - 390 MHZ FREQUENCY. (It is imported to Sweden from the US.)
Does anyone know if I can change this? Not a huge deal if I don't get it to work, but I figured I'd give it a shot and ask.
