SL/R230: LOWERING LINKS ?
Old May 13, 2009 | 07:10 PM
  #226
m4xm1l10n's Avatar
BMW F02 (750Li) F10 (550i)
So who's Ride/wife would this be
Old May 13, 2009 | 07:26 PM
  #227
VendettaMB's Avatar
His wifes head hard into the headboard nightly!!
My ride. My wife. We are sitting I it right now on bcferry on my iphone coming back from victoia,bc. Went and gf abed my passport w/jammers and my lidatek le30 jammers to get installed
Old May 13, 2009 | 10:15 PM
  #228
mlandis's Avatar
2007 SL550
LOL -- ok, ok, looking at the typos, I think you need to get your attention off the headlights and back to the road....
Old May 13, 2009 | 10:23 PM
  #229
VendettaMB's Avatar
its the damn iphone! lol
Old May 13, 2009 | 10:44 PM
  #230
m4xm1l10n's Avatar
hold up !! that photo is your wife ? the actual wife you were mombuling on your last post lol
Old May 13, 2009 | 11:08 PM
  #231
VendettaMB's Avatar
hold up !! that photo is your wife ? the actual wife you wer mombuling your last post lol
that's correct. Wife,my old lady, all of the above.
Old May 14, 2009 | 12:45 AM
  #232
mlandis's Avatar
2007 SL550
Um, m4xm1l10n, I think you need to work on those mouth exercises. Your foot needs to fit somehow...
Old May 14, 2009 | 08:43 AM
  #233
m4xm1l10n's Avatar
HAHA Here u go again . Man i could never thought the guy would actually post his old lady pics with a drop like that lol HHAHAHA !!!! Well since you at it where is the rest of the pictures ?
Old May 14, 2009 | 01:55 PM
  #234
VendettaMB's Avatar
on my phone! lol
Old May 24, 2009 | 05:08 AM
  #235
neomonkey's Avatar
SL500
Back to the scheduled program... I received my lowering links today and was able to install them in about 1 hour.
I didn't have to remove my tires, just jacked up one wheel, popped out the stock link, popped in the new one. Took a few tries to get the height correct. Dropped it 1" in the front and 3/4" in the back. Thinking about dropping it another .25" in the front.
Attached Thumbnails LOWERING LINKS ?-lowered.jpg   LOWERING LINKS ?-lowered1.jpg   LOWERING LINKS ?-lowered2.jpg   LOWERING LINKS ?-lowered3.jpg   LOWERING LINKS ?-lowered4.jpg
Old May 24, 2009 | 05:12 AM
  #236
neomonkey's Avatar
SL500
Old May 24, 2009 | 01:56 PM
  #237
cyberay's Avatar
2015 MB S550 Coupe, 2018 Carrera T, Ford F150
Neomonkey, I have links on order that should arrive this coming week. May I ask how much longer at front and shorter at rear you went with the new links to produce the drops you quoted and show in the photos?
Old May 24, 2009 | 02:37 PM
  #238
neomonkey's Avatar
SL500
On the fronts I went 5mm longer. On the rears I went 3-4mm shorter.
You should do it on a totally level surface. The easiest way to do this is to measure the height of your wheel well on all 4 surfaces. Mine were 71cm high. Then install the links and measure them again. Mine ended up around 69cm, but it changed a few mm depending on how I parked on my driveway since it was sloped slightly.
Old May 24, 2009 | 02:58 PM
  #239
neomonkey's Avatar
SL500
It says on the instruction sheet !!!! Here is a picture of arrow showing side up .
I think I placed one of my links upside down. But can someone explain to me why this matters at all? I know the instructions same to put the longer side up but I can not figure out why this would even matter???
Old May 24, 2009 | 03:02 PM
  #240
cyberay's Avatar
Neomonkey, thanks for the info. Previously I had taken the measurements you suggest. Converted to metric, the wheelwell height is 68.9cm front and 69.5cm rear. The car is an 09 SL550. I would like to reach 67.3 both front and rear. That would mean a reduction of 16mm front and 22mm rear. If I use your experience as a benchmark, lengthening the front link by 4mm and shortening the rear link 5mm should get me there. Do you agree with this calculation?
I will do it in my garage which has a very slight slope of approximately 1" over 24' front to rear. Thanks again.
Old May 24, 2009 | 03:08 PM
  #241
cyberay's Avatar
I haven't received my links yet but as for placing the long part of the link at the top, the only reason I can think of is to make it easier to adjust, especially in the rear, as the jam nut would be more accessible. There shouldn't be a clearance issue and I believe the inserts at either end are the same as well.
Old May 24, 2009 | 03:42 PM
  #242
Artyi's Avatar
Mercedes-Benz SL 500
Well it is hard to answer this question, but it seems that matters. I installed my links 2 months ago, at first try i made the same mistake and ABC went wrong, after installing it in the right way everything went perfect.
But time to time I get this ABC warning message on my board computer, just don't know why... Not in red, yellow color, just in ordinary blue/white color as manually it is. Anyone knows what it could be? It says to check vehicle...
Old May 24, 2009 | 08:52 PM
  #243
m4xm1l10n's Avatar
Sounds weird Arty , as i have never had and error on mine . How low did you go ?
Old May 24, 2009 | 10:38 PM
  #244
j_belll's Avatar
‘23 EQS AMG
damn u posted a pic of ur wife like that lol,
what nationality is she?
Old May 25, 2009 | 04:02 AM
  #245
biophase's Avatar
03 SL500
That sounds good, measuring mm in pretty tough. You are limited to the threading, so its a matter of starting at what you think is correct and then going by number of turns after that.
If you already know where the links are, you'll see that adjusting it is very easy. I made both of mine about 10 mm longer. I installed them and it was too low. So then and took them out and counted the number of turns. Installed again, then uninstalled and adjusted a few turns.
Once you do this, you'll get a feel as to what one turn will do to your ride height.
I used the Mercedes jack and I would be able to jack up a side, pop out the link, adjust it and reinstall the link in about 1 minute.
Old May 25, 2009 | 04:13 AM
  #246
Artyi's Avatar
Well, as I remember I went down like 6mm in front 7mm in back. If my mind don't get me wrong...
Maybe an issue is ABC fault because of it's long use term, already...? But anyways, as I take my car back to the highest position, stay for 15sec and get to normal it works fine.
Once I came back to my car and one side of it was a little bit higher, so I made the same process with height and it came back to normal again...
Don't know, I'm a little bit confused about this ABC, because as I read lots of threads here it is an expensive s*it.. And I have got no warranty..
Old May 25, 2009 | 12:14 PM
  #247
cyberay's Avatar
I'm using a floor jack and will be able to do the same.
From what I can tell, the pitch of the screw is 1mm so each full turn will change the overall length by 1mm. From postings and from speaking to John at Adjustable Air Ride, a 1mm length change of the link will cause a 1/8" change in ride height. This is useful info for somebody like me who hasn't done this before.
I have a minor concern about the plastic sensor arm and whether it can be broken if the link is hard to disconnect. Maybe it should be supported with pliers when doing this?
Old May 25, 2009 | 02:14 PM
  #248
biophase's Avatar
03 SL500
I never felt that this arm was in danger of breaking.
I did it the same the instructions said, I put an adjustable wrench on the link, you are using the wrench like pliers. Then twisted the part off at the top joint first by turning the link. I did not pull the link off the ball, rather torqued it off.
Old May 25, 2009 | 03:12 PM
  #249
cyberay's Avatar
I'm sure you're right. I'll twist it off like everyone else did without a problem. Btw, you're car looks real good.
Did you bother to remove any of your wheels for the instrallation or adjustments?
Old May 26, 2009 | 03:37 AM
  #250
neomonkey's Avatar
SL500
I just realized that I've been posting in this thread under 2 names: biophase = neomonkey Hope I didn't confuse anyone. My work computer and home computer cookies are different so I log in as different people. And since I have it autologin I never noticed it until right now.
Anyway, to answer your question I did not have to remove any tires at all.
Just jack up the fronts enough until you can clearly see the link.
On the backs I jacked it up about 7". Lay down, slightly under the car and then reach behind the tire to get to the link. (Make sure you put something else to hold up the car, don't just rely on the jack) You can only see about half of the link. You can't see the lower ball, but you can get to the top one and twist off. It's a little tight doing the back, I had to use a pair of pliers to twist it off.
