SL/R230: LOWERING LINKS ?
1. I have read that the R230's lower up to 1" at highway speeds. So if your car is all ready super low does it get to the point of being unsafe at high speeds? What I mean does it continue to lower down the faster you go, and do you run the risk of damaging your fender lips and undercarriage on the highway?
2. Does this add more wear to the already problematic ABC suspension and struts?
3. Will this effect or void any part of my warranty?
I look forward to hearing from people with more experience then myself!
Thanks in advance!!
-Chris
as you know with these links you can make the sl a lowrider if you wanted to but i like were its at right now.
Delorean you should set your links to low on your low abc setting but drive on the highway in your middle abc setting. this way you don't feel all the highway bumps and maybe damage your rims. but otherwise its pretty safe.
i cant answer your questions about wear and tear. I've had mine on for almost 2 years with no problems so far. as for warranty issues i suspect most dealerships would try and find a reason not to warranty a suspension problem if they see your links. so i would take them off before taking it in for a suspension issue
Thanks in advance!!
-Chris
Q. How will the ride be once lowered?
A. The lower you go the more stiffer it will feel.
Q. Will lowering my vehicle improve the handling?
A. Yes. A lower center of gravity always helps
Q. Will the raise button inside the vehicle still work?
A. Yes. Depending how low you go, once lowered the highest setting will be approx. the same height as the lowest setting before the vehicle was lowered.
Q. Will I need an alignment?
A. Any time a vehicle is lowered it should be checked. The wheels will Camber in. With my car lowered about 1.25" I have not had it done and notice slight inside ware on the front tires. I personally like a little Camber look so will sacrifice a little tire ware.
Q. Will the ABC Sport button still work?
A. Yes. When applied you will still have that extra sporty feel.
Q. What height do you mostly drive at?
A. It depends on my mood. I find that there is such a difference between the settings now. Lowest with ABC Sport On feels so sporty yet raised all the way with Sport Off is nice and smooth. Find I use the Raise button a lot more. Before lowering would never use it, was almost like a 4x4 when raised.
Q. Can this kit be installed with basic mechanical skills?
A. Yes definitely. All that's needed is a jack, jack stands, couple wrenches and pliers. The Porsche Cayenne can be done without jacking.
Q. How low can I lower my vehicle with the Links?
A. Lower then you can possibly drive.
Q. How will the Lowering Links effect my warranty?
A. We have all heard stories how dealerships try to deny claims for any reason. Our kits have never caused any issue on any vehicle. If for some strange reason someone did have a problem with their Suspension System we recommend to remove the Links and put the stock 1's back. That's another advantage of our kit. It can be done in 30 min. and there will be no trace of it unlike Electronic Modules with cut wires.
What do you guys think? Is this normal? Feedback would be appreciated. Here's a pic.
One thing is 4 sure it looks good dropped
(FYI: It was far too cold to have the top down.)I'm sure many would classify that as child abuse, but I doubt the kid was actually having a bad time. I can recall the strange things I did as a teenager to ride in my friends' fast cars!
Rook
What do you guys think? Is this normal? Feedback would be appreciated. Here's a pic.Thanks man !!
http://www.cardomain.com/ride/3240011
I'm thinking 1" back and 1.25" front
