SL/R230: LOWERING LINKS ?
Old Apr 21, 2009 | 01:53 AM
  #151
sikhkd's Avatar
AMG
Originally Posted by FreshBenz
here's my car lowered with links today:
Now that's one fresh benz!
Old Apr 21, 2009 | 12:15 PM
  #152
Sunir's Avatar
SL55 AMG
Originally Posted by gqa
here's the link to a thread with some info on the roof module
https://mbworld.org/forums/sl-class-...of-module.html
very nice sl
George lemme know a couple of weeks ahead of time when you plan on coming back around my way...I'll order those links and when we're up at Scott's maybe we could do the links there with a lift, much easier! Figure we'll be there for my resonators and whatever work your planning on gettin done...
these cars are looking too good with these links!!!
Old Apr 21, 2009 | 12:20 PM
  #153
m4xm1l10n's Avatar
BMW F02 (750Li) F10 (550i)
Sunir you will love it , I did get a set of SL55 pipes , so am in business
Old Apr 21, 2009 | 12:25 PM
  #154
Sunir's Avatar
SL55 AMG
Originally Posted by m4xm1l10n
Sunir you will love it , got me a set of SL55 pipes , so am in business
Max I'm from MD close to Rockville and south of Bmore maybe 20 mins, George came down here to pick up the exhaust so he's familiar with this area...you should coordinate to come down...meet Scott maybe talk about doing some custom exhaust work for ya as well...heck with the few of us there we should be able to do my links in no time and get some exhaust work done for each of us in short order!
edit: just saw u have SL55 pipes and tips, he could weld those bad boys up but you're gonna need to mod your rear bumper cover...it's gonna look hot though...
Old Apr 21, 2009 | 02:27 PM
  #155
gqa's Avatar
gqa
05' sl 500
no problem Sunir, I'll keep you posted
Old Apr 21, 2009 | 05:32 PM
  #156
m4xm1l10n's Avatar
oh man what a ride that would be for me
Old Apr 23, 2009 | 02:34 PM
  #157
LILG's Avatar
SL500
NICE
Old Apr 23, 2009 | 02:39 PM
  #158
LILG's Avatar
SL500
very nice sl
Very good info, Thanks GQA
Old Apr 23, 2009 | 02:42 PM
  #159
LILG's Avatar
SL500
pretty soon Mercedes will be offering the links as an option
NO MORE STOCK HEIGHT SL'S ON THE ROAD!!
Old Apr 23, 2009 | 02:54 PM
  #160
m4xm1l10n's Avatar
yep
Old Apr 23, 2009 | 03:03 PM
  #161
Badr1's Avatar
2003 SL-500 AMG
What are your thoughts about lowering cars using these links ?
http://www.adjustableairride.com/index.php
checkout Midwest Controls online to fabricate (4) HEIM joints stainless steel with adjustable turnbukles for fractional height adjustment
Old Apr 23, 2009 | 06:13 PM
  #162
m4xm1l10n's Avatar
Check out what ?
Old Apr 24, 2009 | 12:58 AM
  #163
OUTCAST's Avatar
SLK55AMG, SL600
Just got mine in going to install this weekend
Old Apr 24, 2009 | 08:53 AM
  #164
Badr1's Avatar
2003 SL-500 AMG
Check out what ?
Max,
sorry, i thought i replied to formum in lieu of your post. Apologize for the confusion.
Midwest Controls has quality HEIM joints and misc threaded hardware to fabricate quite simply, lowering links. Cost is about $75 for stainless and aluminum.
Old Apr 24, 2009 | 11:06 AM
  #165
m4xm1l10n's Avatar
o ok too late for me now as i already have them . but i need them for my S class . two for the fronts , rears are already adjustable . How can i get info on this ?
Old Apr 24, 2009 | 11:27 AM
  #166
Badr1's Avatar
2003 SL-500 AMG
go to www.midwestcontrols.com to see what you need to fabricate each link. there are many ways to do it and different material you can use from steel, aluminum to stainless steel 10-32 machine screw size should work best, but parts go up to 1/2" in size with metric parts as well.
good luck
Old Apr 24, 2009 | 11:30 AM
  #167
Badr1's Avatar
2003 SL-500 AMG
here are te HEIM joints i used "male \ male with 90 degree units. you will need (8) 10-32 x 4" machine screws and hex "stop" nuts and (8) hex essin nuts "nuts with plastic inserts" they act like lock washers. All can be purchased at home depot or lowes in stainless steel or steel.
8
EMS187
Ball Joint, Male
USD $2.55
USD $20.40
4
FT187F-3.312
Turnbuckle, Forged, Inch
USD $2.64
USD $10.56
Subtotal
USD $30.96
Shipping and Handling
USD $13.80
Total
USD $44.76
Old Apr 24, 2009 | 05:52 PM
  #168
m4xm1l10n's Avatar
HAHAHAH It might sounds strange but a rather pay the money for those links . just makes me feel safer .thanks anyway
Old Apr 25, 2009 | 01:42 AM
  #169
biophase's Avatar
03 SL500
good luck
Do you mean this company?
http://www.midwestcontrol.com/catdis...ort.php?pg=229
http://www.midwestcontrol.com/237.php
Old Apr 26, 2009 | 04:12 AM
  #170
mlandis's Avatar
2007 SL550
I was going to use some of those extra screws that came with my IKEA cupboard...
Old Apr 30, 2009 | 01:40 PM
  #171
Badr1's Avatar
2003 SL-500 AMG
Question
You can go as low as you like it's safe but also commonsense , if too low you'll bottom out and the ride quality is bad and bumpy . I went 1" all around so 3mm difference from the stock links in the front (longer) and 2mm in the rear (shorter) and i love the looks and the ride is perfect
do you mean 2 to 3 mm from teh "stock links" as in teh OEM non-adjustable "original links?
Old Apr 30, 2009 | 01:59 PM
  #172
Badr1's Avatar
2003 SL-500 AMG
yes, but use female HEIM - TURNBUCKLE JOINTS.
Old May 1, 2009 | 04:20 PM
  #173
m4xm1l10n's Avatar
I did 3mm longer than the stock links in the front and about 2mm shorter in the rear . i have little less than 1" drop on my car but i'm thinking on going lower a bit .
Old May 1, 2009 | 05:19 PM
  #174
j_belll's Avatar
‘23 EQS AMG
u can go a lot lower, slam that ****. my SL is slammed and its only bumpy at slow speeds, like under 10 mph. the ride is good just gotta be very careful!
Old May 4, 2009 | 12:45 AM
  #175
Auraraptor's Avatar
Just wondering...
How much does the car raise (OEM) every time you press the button?
I am trying to figure out how much I want to lower my car exactly. (The goal is have the middle setting close to the factory low setting at most).
