SL/R230: LOWERING LINKS ?
Old May 4, 2009 | 08:30 AM
  #176
Badr1's Avatar
2003 SL-500 AMG
Originally Posted by m4xm1l10n
I did 3mm longer than the stock links in the front and about 2mm shorter in the rear . i have little less than 1" drop on my car but i'm thinking on going lower a bit .
Max,
Thanks again for your input.
Can i trouble you to take a (4) corner measurement from ground to edge of each fender? I'm looking for someeone with 295 - 25 - 20" tires and is lowered like your.
If you can forward each corner dimension so i can compare would be fantastic. If to much trouble, don't worry.
Thabnks again
Old May 4, 2009 | 09:51 AM
  #177
m4xm1l10n's Avatar
BMW F02 (750Li) F10 (550i)
I can do that , but i don't think that would explain anything . My car is lowered a hair less than 1" to be more precise . And I'm running 285/30/20
Old May 4, 2009 | 09:56 AM
  #178
m4xm1l10n's Avatar
Originally Posted by Auraraptor
Just wondering...
How much does the car raise (OEM) every time you press the button?
I am trying to figure out how much I want to lower my car exactly. (The goal is have the middle setting close to the factory low setting at most).
Mine at first setting ( 1 red light ) it goes back to the car original high . once on 2nd setting it goes up more , but not as much as it did before the links .
Old May 4, 2009 | 11:04 AM
  #179
Sunir's Avatar
SL55 AMG
Originally Posted by FreshBenz
u can go a lot lower, slam that ****. my SL is slammed and its only bumpy at slow speeds, like under 10 mph. the ride is good just gotta be very careful!
lowrida stylez for sure! ...hittin' da switch on dem lolo's
Old May 4, 2009 | 11:34 AM
  #180
m4xm1l10n's Avatar
HAHAHAHAH
Old May 4, 2009 | 11:45 AM
  #181
Auraraptor's Avatar
You have a one inch drop all around right? Or is the rear a touch more then the front?
Old May 4, 2009 | 01:16 PM
  #182
m4xm1l10n's Avatar
front is lower a tinny bit but my car is not slammed at all .
Old May 4, 2009 | 02:36 PM
  #183
Auraraptor's Avatar
Nice! That was the 3 turn Front/2 turns rear setup right?
Old May 4, 2009 | 08:46 PM
  #184
m4xm1l10n's Avatar
you mean 3 turns from the stock link size ? i did 3MM longer than the stock ones on the front and 2mm shorter on back and it dropped almost a full 1" , but im thinking lower now .
Old May 5, 2009 | 08:35 AM
  #185
Auraraptor's Avatar
Thanks for the correction.
Last thing...have you tried high speed driving in that setting? Do you raise by one for driving on the highway? I don't want problems at 100+.
Old May 5, 2009 | 11:34 AM
  #186
m4xm1l10n's Avatar
no way man it's fine i never raise my vehicle , and my drop is not that much eider . Here is a few pictures on the freeway .
Old May 5, 2009 | 11:54 AM
  #187
OUTCAST's Avatar
SLK55AMG, SL600
Nice i got my link and going to do it this weekend. Also I am running 305/25/20 in rear, if i use your setting do you think i will be fine.
Old May 5, 2009 | 11:59 AM
  #188
m4xm1l10n's Avatar
Should be OK cuz the 305 is big man , i think it would rub w/out the drop anyway
Old May 5, 2009 | 04:22 PM
  #189
playdo's Avatar
sl500
looks like your running 245/35/20 in the front. Will 255/30/20 rub?
Old May 5, 2009 | 04:42 PM
  #190
Auraraptor's Avatar
No. It has less sidewall.
Old May 5, 2009 | 04:56 PM
  #191
Auraraptor's Avatar
Max, what is your tiresize Front and rear?
Old May 5, 2009 | 05:15 PM
  #192
m4xm1l10n's Avatar
245/35/20 F
285/30/20 R
Yokohama S-drive
Old May 5, 2009 | 05:19 PM
  #193
m4xm1l10n's Avatar
No it will not , It's also the other option from 245/35/20
Old May 5, 2009 | 05:24 PM
  #194
Auraraptor's Avatar
245/35/20 F
285/30/20 R
Yokohama S-drive
Why 245 and not 255? Or is your car a 500?
EDIT: I just ordered a set of links
Old May 5, 2009 | 07:54 PM
  #195
m4xm1l10n's Avatar
Doesn't really make a big difference going 255/ 30 but i would be sacrificing the side wall height witch makes a difference when u hit a pot hole
245/35/20 & 285/30/20 gives you a impressive ride quality , handles pot holes , rides smooth and looks aggressive , for example most of the 911 turbo , wide body etc with 295/315 on the rears only runs 225/235 on fronts
Old May 5, 2009 | 08:36 PM
  #196
Auraraptor's Avatar
It makes a huge difference, less so if your car is a 500. (Not in a bad way, they were setup up differently then the 55/600/65)
As for the Turbo comparison: That's because its suspension was setup differently...namely with a more aggressive rear balance AND it is Rear engined/biased. We are front engined with a much gentler F/R suspension balance. Apples-Oranges.
In short, your setup would worsen understeer in cars already prone to a lot of it.
This is why I was so interested in your front and rear drops each alone, as that will change the balance too. Too much rear relative to the front will make the car just awful to steer (again in IMHO), but it appears you got a great balance setup.
Old May 5, 2009 | 10:08 PM
  #197
m4xm1l10n's Avatar
I have the SL500 and If I'm not wrong and please someone correct if I'm wrong I think they have the same suspension set up (ABC) between the SL600, 500 & 55 . And also why isn't the SL55 equipped with wider tires than the SL500/600 ? on 18" option all cars are running 255/40/18 & 285/35/18 including the non sport package with 18" wheels
My car is 9MM lower than stock F & R
Old May 6, 2009 | 12:39 AM
  #198
mlandis's Avatar
2007 SL550
Unless I'm mistaken, the car ignores the height settings button over 55MPH -- it goes to the bottom position at that point.
Old May 6, 2009 | 01:41 PM
  #199
Sunir's Avatar
SL55 AMG
A few points:
1) SL55 runs ABC just like 500 but the valving is more aggressive; 55 suspension parts (namely ABC struts and not the same p/n as 500 or 600)
2) both 55 and 500 run 255 F and 285 R on 18's stock; that's a function of the weight of the car and the load applications from the chassis. A 911 can run a much narrower front tire due to weight and brake bias and chassis/engine config; this does not translate to the R230 chassis
3) The SL will understeer even with a wider front tire; reducing the width of the front tire can make it understeer more on corner entry.
- I am running 245/35-19 F on 8.5" rim and 285/30-19 on a 10.5" rim ... my next choice will be stay with 245 or go to 255 in front and go to a 295 or 305 in the rear once I do the tire height calculations for front to rear compliance
Old May 6, 2009 | 02:36 PM
  #200
Auraraptor's Avatar
A few points:
I have heard the programing differs as well.
What is your rear offset? ET30? I am trying to figure out what rear dimensions I want to build.
Here is the specs I have done for my setup (I may have to do a 20in rear if they don't make my wheel):
