SL/R230: How to diable alarm..KEEP it from going on, not just turning off. or SILENCE IT.
Old 05-10-2009, 08:25 PM
VendettaMB's Avatar
His wifes head hard into the headboard nightly!!
How to disable alarm..KEEP it from going on, not just turning off. or SILENCE IT.
i have searched but no good answers how to either:
A) silence alarm
B) de-activate so it wont arm when LOCKING doors.
thx
Last edited by VendettaMB; 05-10-2009 at 10:23 PM. Reason: i spell like an idiot!!
Old 05-11-2009, 12:59 AM
m4xm1l10n's Avatar
BMW F02 (750Li) F10 (550i)
Goes off by itself ? how about lights any of it goes on too ?
Old 05-11-2009, 01:27 AM
VendettaMB's Avatar
as soon as i lock doors, and walk away..i guess it takes 15sec. to activate them IT STARTS CHIRPn away..not all the time..never at home( i think as in underground in condo)..only 50% of the time in public..so random, then do it 3x or so then its ok.
can it be locked w/o alarm, or at least silent mode?..sensitivty adjusment?
i havent even looked to see if its the lights also, so quick to turn it off of embarassment.
Old 05-11-2009, 09:40 AM
daltex's Avatar
03 SL500
May be easier to track down what is causing the alarm to activate.
Could be a faulty door/trunk/hood switch or just them being out of adjustment.
If not those you may want to pay the $tealer/indy to do a diagnosis on the alarm system.
Old 05-11-2009, 11:32 AM
VendettaMB's Avatar
Thx. That is a good suggestion. But until I have time I need to stop the noise and save my battery. Maybe I can pull a fuse. As it is I don't lock car when I park if it just goes off. You would think there is a way to make it silent, as so many people get towed with alarms that go off.
Also I have never seen a fault or anything saying alarm, or door, trunk. Which you would think would indicate that if enough to set off alarm, but it may be. I will double check. Thx for yr help
Old 05-11-2009, 05:12 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
In the main fuse box you will see a row of fuses. Removing the 3rd fuse from the left should disable the alarm siren and nothing else. This is a 7.5-amp fuse.
Old 05-11-2009, 05:22 PM
VendettaMB's Avatar
beautiful..i will give it a try. tried to go for lunch but it wouldnt stop. i went home and it did after 1 reset...so random. taking in thursday, but that will help on draining batt and annoying siren till then, thx
Old 07-26-2009, 03:25 PM
VendettaMB's Avatar
replaced BOTH batteries With MB, had MB look at it..still drains my consumer batt everytime!!! AAAARRRRGGGGGHHHHH!!!!!!!!!
Old 07-26-2009, 03:30 PM
VendettaMB's Avatar
flashes
Will the alarm when disabled FLASH certain amount of times to tell me it has gone off or why? what flashes mean what when arm/disarm.
thx
Old 10-15-2009, 08:46 PM
VendettaMB's Avatar
after 1 month i got my car back from MB dealer today..gave me keys and it was dead! so they tossed new battery in it(as i bought 2 new ones about 3 mo. ago)..so i will see what happens over next few days..OH now instantly my dash throws errors for low beams and they are off, then came back o after i restarted car, $4700+$$$ bill. i luv mercedes cars!
Jay at dealer was great. too bad the car isnt.
Old 08-28-2010, 04:13 PM
NikleinR6's Avatar
08 ML350, 2011 E550 Cab
Ever figure out why the alarm was going off for no reason... After washing and detailing my car recently, i now have this problem. As soon as i lock the doors, it takes about 20 sec and the alarm will sound.
Its driving me crazy...
Nick
Old 09-08-2010, 12:42 PM
NikleinR6's Avatar
Figured out the problem..
Here was the problem..
And solution
https://mbworld.org/forums/sl-class-...y-fix-diy.html
swfunhog (09-16-2016)
Old 08-11-2013, 01:52 AM
erik oberdorf's Avatar
cl500
Thats some ignorant *** **** in the third
Fuse from the left lol. Theres alot of rows dont post stupid **** give a fuse location.
Old 06-03-2016, 01:44 PM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
The 3rd from the left (top left in this picture) is the power fuse for the siren (F25) (K40/2 F25)
Chris
Attached Thumbnails How to diable alarm..KEEP it from going on, not just turning off. or SILENCE IT.-r230-siren-fuse.jpg
George993 (09-22-2020)
Old 09-14-2016, 08:30 PM
jonthebass's Avatar
ML 55 AMG
Alarm Randomly going off
Above your head whilst in the drivers seat is your trip/fuel display. To test if it is your sensitivity for "towaway or broken glass" simply press the right hand (Opp to reset) button until "off" is displayed. You must do this within 15 seconds of switching your engine off. Once "off" is displayed you can then go and lock your doors. If this works then you know it is the glass break sensor that needs replacing. Pain in the proverbial I know.
Old 09-14-2016, 11:24 PM
MBworld Guru
Rudeney's Avatar
Received 1,000 Likes on 869 Posts
NO LONGER ACTIVE
There is no glass breakage sensor in the SL. There is a tow sensor, and it can be disabled by pressing the button located in the center console, below the gearshift lever.
One common problem with the ATA siren is that it dies. It's located under the fender liner, behind the front left wheel. Even with the liner in place, it can still get road salt and water in it that destroy it. Also, it has a built-in rechargeable battery that will eventually die and leak onto the circuitry.
Heatwave (09-15-2016)
Old 09-15-2016, 01:16 AM
jonthebass's Avatar
ML 55 AMG
Alarm problems
I was referring to the ML 55 AMG which has the sensor. Pain in the butt
Old 09-15-2016, 01:23 PM
Heatwave's Avatar
2007 E350; 2018 GLE350
Rudeney: On R230 cars ... does the tow sensor button turn red to signal that it's active and that the tow alarm system is "on duty," or does it turn red to signal that the tow alarm is deactivated?
Old 09-15-2016, 08:31 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Yes, I had an ML and remember issues with the glass breakage sensor. What year is yours? If it was built from April 2001 (so late MY2001 or MY2002), there was a known issue with the sensor and it needs to be replaced.
Old 09-15-2016, 08:33 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
When you press the button, the red LED indicator illuminates and this means that the tow sensor is disabled. When the indicator LED is not illuminated, the sensor is enabled.
Old 05-12-2017, 07:30 PM
Harrco's Avatar
SL500
sl500 siren fuse
Chris
Thanks. Worked for me. I did not have to remove the siren, just the fuse, which was much easier. MB told me I needed a front SAM which was very costly, but removing the fuse fixed my problem and saved me lots of money. Now I can lock my doors with the smart key and no siren or flashing lights. Thanks again.
Old 08-10-2017, 02:24 AM
kiwigirl's Avatar
E350 coupe
Can anyone tell me if this worked or works?I hate the alarm.
Old 01-05-2018, 01:18 PM
Bubba Olive's Avatar
500 so Year 2000
in the trunk the 15 fuse second from bottom is the alarm fuse. Pull out and it shuts it off. Will also make the phone(if you still have one connected in the car) beep for about 30 seconds when you start it or put key in but will then shut off.
Old 01-05-2018, 02:23 PM
kiwigirl's Avatar
E350 coupe
Alarm
It worked. Thank God. NO Alarm
Old 06-30-2018, 08:55 PM
sjv123's Avatar
SLK 230
I am trying to pull the fuse for my slk, but none of the fuses are named for the alarm, which one is it please?
Quick Reply: SL/R230: How to diable alarm..KEEP it from going on, not just turning off. or SILENCE IT.
