SL/R230: DIY: Brake Job (Front & Rear) Question
I am getting ready to do the front and rear brakes on my '03 SL500. I have new front rotors, ceramic pads, wear sensors, MB hi-temp grease, and brake fluid.
Are there any secrets? Should I disconnect batteries? After finishing, will I have to turn steering wheel from side to side to clear faults? Is this going to be an easy job?
Thanks in advance.
Thanks in advance.
I replaced my rear pads two weeks ago. Very easy.
As stated above, the big thing to remember is to unplug the SBC sensor, or you can turn the system off if you have a STAR system.
The STAR systems are a little pricey, but they are a huge help with so many different items and systems... from lowering the car to diagnosing every component. I have had a number of clients buy STAR systems from us, and use them for several years and sell them on for what they paid for it when they sell their car.
Good luck with the brake job, and did I say to disconnect the SBC plug?
Zimmerman brakes have a good reputation.
http://benzbits.com/R230/DeactivateSBC.pdf
You don't need unplug the SBC, and you do not require using Xentry or STAR diagnosis.
Unplug the battery in the boot before you start working, do your work, connect again. While the battery is disconnected, the cars electronics don't recognize any things you do, and you don't get any error because you disconnect and reconnect the wear sensors on the pads.
I have done the brake job several times on both my previous SL55 and my current car, only disconnecting the battery, and pumping the brake pedal to hard feel, before connecting the battery again. No problems, no errors.
If you disconnect the SBC, chances are that the car recognize it, and you have to erase an error after plugging it again, plus the errors from the wear sensors.
Furthermore, I have bad Experience with disconnecting and reconnecting components, while the battery is connected.
Am on the other side of the pond here... when you say "boot" is that what us yanks know as the trunk which houses the accessories battery in the rear of the car?
And if so, what procedures need to be done when the accessories battery is reconnected? Anything that needs to be cycled or procedures to relearn how the accessories operate... for example the power windows, roof, trunk (boot) latch, etc etc etc
Also, do we also need to disconnect the starter battery under the hood (or I guess bonnet) ?
George
George
Yes the "boot" is the Trunk, and yes the accessories battery is the battery in question.
On the SL, the windows have to be realigned, meaning, doors closed, roll em down, roll em up, let go of the buttons, the windows will go down a bit, roll em up again.
No further action is needed.
You will get a ABS and or ESP alarm, but it will disappear as soon as you have driven half a mile.
That is something I can definitely handle without having a SDS tool.
All I have is a iCarsoft MB II code reader, recently acquired from the MBWorld "maketplace" .
Thank you sir
Simple.
PM me if you want before you go into the wrong direction with DAS / Xentry Diagnostics Choice
"The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten"
