SL/R230: How do i remove the instrument cluster ?.
Old Mar 18, 2010 | 05:15 PM
carlosamg50's Avatar
AMG GLS63
Hi all
As per the title, how do i remove the instrument cluster from my 2003 SL500 ?. I need to take it out to send it away for repair and dont want to start pulling at the plastic shroud incase i need to unclip it or something ?.
Has anyone ever done this on an SL R230 ?.
Carl
Old Mar 19, 2010 | 03:20 AM
daltex's Avatar
03 SL500
Order the DVD
Old Mar 19, 2010 | 03:45 AM
AMG GLS63
Which DVD ?.
There are so many on places like eBay i want to be sure i get the right one for a UK SL ?
Carl
Old Mar 19, 2010 | 01:09 PM
daltex's Avatar
03 SL500
Get the $70/80 one from the $tealer.
Search the forum the part number is somewhere.
Old Mar 19, 2010 | 08:00 PM
omar26's Avatar
E55
1. pull off the the bezel around the cluster (pull straight out)
2. remove the 3 screws holding the cluster down
3. pull the cluster out and remove the wire harness
ps: make sure you disconnect both batteries before
Old Mar 20, 2010 | 08:03 AM
AMG GLS63
Hi omar26
Will i have to reset all the memory settings when after i disconnect the batteries ?.
Im new to SL ownership and just want to be clear before i start the work.
So the bezel isnt screwed on / clipped on ? It just pulls straight off ?.
Carl
Old Mar 21, 2010 | 05:05 AM
AMG GLS63
Also, whats the correct procedure for disconnecting them ?.
I dont want to just pull the leads and blow something.
Carl
Old Mar 21, 2010 | 08:57 AM
AMG GLS63
Ok, so forget my question about battery disconnection i should have read my manual first.
I tried to pull the bezel straight off and unless it takes a mighty force it must be clipped in or something ?. It wasnt pulling off and i had to stop incase it broke. It was bending at the bottom front where the steering column comes through to the point where it would snap if i kept going.
Any ideas ?.
Im going to buy a DVD but here in the UK i cant get one from a dealer so it will take a few days for that to arrive and i had hoped to do this ASAP.
Carl
