SL/R230: oil change
Lubricants are much better than they used to be and last much longer and there's less wear and especially water absorption to start with. Critical though is that when the oil does need changing, the car gets the oil specifically recommended for the engine and not some old gunk you bought at Wal-Mart several years ago. This also means taking it to the dealer instead of one of these jiffy-lube places who have a vested interest in you coming back for the next dose of sludge.
The car service record includes the amount (time/mileage) by which you over or under-shoot the recommendation and a correctly stamped book of on-time maintenance is going to give the next owner of your car all the warm fuzzies he needs.
Bottom line is that you're wasting your money changing the oil any more often, you'll never see any benefit.
Similar story to with the automatic transmission which is sealed for life and requires no change of ATF fluid, I believe there's even no way to check the level now on the basis that "we put it in there so it must still be there".
However, I do not agree with the lifetime fill on the Auto Trans boxes. I don't think even MBtech208 will agree with it.
Nothing lasts for life. If you plan to keep your car past its warranty period, a little prevention can go a long way.
MBtech208, what is you view on the lifetime ATF fill ?
I could argue the 10,000 mile oil change, but all in all I think it's probably ok. I persoanlly choose to change the oil between A and B FSS services. Usually at 5,000 miles.
As for the engine oil, it may be the harsher extremes of climate in the US mean more rapid deterioration compared to here in the UK but I doubt Mercedes would risk their reputation for longevity of their cars by artificially inflating the service interval.
My SL600 has so far done 72000 miles and uses (burns/leaks) no oil at all - none. I've never yet needed to add oil between the services and I do not suppose the SL55 will be significantly different. In fact, the manual cautions about over-enthusiatic topping up of oil which can lead to engine damage. The AMG V8 it seems can have too much of a good thing.
Certainly technology has improved maintenance cycles on engines and transmissions.
I remember as far back as 10-15 years ago, I was speaking with numerous people in the US about oil changes on their Mercedes' (126 and 140 bodies). To my amazement, many replaced it as often as every 3000-4000 miles.
I did a fair amount of driving in Germany where you truly push the engine when going for hours near top speed. At that time the standard oil change interval was 10,000 km (6200 miles).
At Mercedes (not just a dealer), I asked some people about the benefit of that habit and the general answer was "A total waste of money". Their point was that even the 10000 Km cycle was considered preventative by Mercedes, already changing it more often than actually needed.
Changing the oil more often than the recommended service cycles will certainly not harm the car, but it may not improve the engine life either...
Wolfman
My Ferrari is meant to have its cam belts changed every three years and it's big money - $3000 to change $100 worth of belts because the engine has to come out and currently, I'm 15 months overdue. Am I worried? No. The last time it was done, the belts being replaced were pretty much indistinguishable from new.
I don't adhere to the strict three-years-or-it's-armageddon because I know how I drive the car. A 355 being driven hard is well beyond my abilities to control it if all goes horribly wrong and I do not drive it as hard as some might, but nor do I leave it unused for months on end. I'm also kind to engines and let them warm up before extending them.
So, my belts will last a while yet and if they do let go and wreck the engine, the flaw in my logic will be exposed for all to see!
