SL/R230: Car vibrates, especially when cold. Any thoughts?
Old Oct 7, 2012 | 04:02 PM
Wolfman's Avatar
Super Moderator
A couple of weeks ago, our SL600 (late 04 build) started feeling rough when driving. After about 10-15 minutes, it seems to drive smoother.
The roughness feels like a vibration, especially in the mid-section of the car (for example when the car stands in park and you step on the gas).
The engine actually sounds smooth while revving but not when you sit in the car.
I brought the car to the MB dealer, which observed the same thing over the a few days, but couldn't find any fault codes, etc.
Now at 75k, we had the spark plugs replaced (their first thought) as well as one of the coils a while back.
Eventually they found that the motor mounts have collapsed on the left side and thought that might be the cause.
At $3100 to repair that I don't feel that I want to just take their word do it, especially as the behavior should be consistent, cold or warm if that's the issue.
Plus when I revv-up the engine in the garage, it's sit rock solid in the car (no engine movement whatsoever), yet I still feel the vibration.
Could it be something besides the engine? Exhaust, catalytic converter, etc.
The cars pulls strong and still fights with the traction control at 60+mph, so I had ruled out motor mounts as a cause.
Sorry for the long explanation, but am looking for clues.
Thanks!
Old Oct 7, 2012 | 08:55 PM
CLUBVIEW's Avatar
2004 SL500 2001 S430 2006 C230 1995 C280 1988 SL560
I have the same problem I think it is more at 2000 RPM also my dealer says motor mount are collapsed (both of them) but he gave me estimate of 1100 why yours 3100?
Old Oct 7, 2012 | 09:09 PM
Wolfman's Avatar
Super Moderator
It's a SL600.
The engine is significantly larger than the V8 and must be completely removed to replace the mounts. Parts including the transmission mounts are only a couple hundred bucks, but the labor is estimated at a whopping 18 hours!
Which unfortunately is not unrealistic
Since I am toying with the idea of a 2013 SL63 (if I ever get used to the front-end), I am weighting the value of the repair. Especially since the dealer will not guarantee that the vibration will be gone with new mounts...
Old Oct 7, 2012 | 09:34 PM
CLUBVIEW's Avatar
I can see your point
I was going to buy 2009 S600 and got concern because of high repair cost on the 12 cyl models
Old Oct 7, 2012 | 10:02 PM
Wolfman's Avatar
Super Moderator
I would never let that influence my buying decisions. The V12 is so dramatically better than the V8!
All MB repairs without a warranty will be expensive, wether it is a 500, 600 or AMG variant.
That engine will put a smile on your face every time you drive the car and with an chip tune, you'll blow just about anything out of the water, including many AMG and M-cars...
Old Oct 8, 2012 | 10:25 AM
Welwynnick's Avatar
2006 S600
I think the first thing to do would be replace the transmission mount. Its only a few $ and a few minutes. It might not be the solution (though it often is) but I would like to cross that off the list first.
Otherwise I'd guess it probably is the engine mounts.
Old Oct 8, 2012 | 11:45 AM
Wolfman's Avatar
Super Moderator
Sounds like a great idea. They were going to replace the transmission mount just as a matter of completeness, but that should be cheap one to start.
Perhaps it makes a difference...
Old Oct 8, 2012 | 12:50 PM
rune solem's Avatar
SL 55 and a GT 3000 vr4 Here's my car: http://home.online.no/~ludvs/index.cfm
Maybe a stupid question...
Why is the engine mounts design on the sl600 and sl65 made so you have to remove the motor??
I'm not an mechanic, but I would think that mercedes could have made a different design to the mounts so they didn't have to do that big a job?
Old Oct 8, 2012 | 01:53 PM
Wolfman's Avatar
Super Moderator
Well it may be possible on the 55 engine, but the V12 is simply much bigger, leaving no space to get inbetween.
Here is a great picture thread. Wish it would need that kind of effort either:
https://mbworld.org/forums/sl55-amg-...sl-models.html
Wolfman
Old Oct 9, 2012 | 05:41 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Check your tranny mount first, that is an easy change.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jan 8, 2013 | 12:44 PM
Wolfman's Avatar
Super Moderator
Update.. We ended up replacing both the motor mounts and transmission mounts and while the engine was out also took take of replacing the seals of both turbos.
Pricey as expected but it made a world of difference. Now runs smooth as silk Just wish we wouldn't have all this snow around
Old Jan 8, 2013 | 01:26 PM
CLUBVIEW's Avatar
I fixed problem on my SL500 2004 changed the Trans mount and engine mount no more vibration it cost 850 dollars for engine mount and 300 for trans mount
Old Jan 9, 2013 | 09:33 AM
egwu's Avatar
2003 SL500, 2005 ML500 SE, 2005 CLK500 Cabriolet Avantgarde
OK. Seems I need new mounts too then, because I am experiencing the same symptoms. It seems these mounts go out quickly because I remember changing mounts not too long ago. A year or so ago...
Old Feb 11, 2013 | 10:41 AM
mitviet's Avatar
Daytime: Slow and easy with 2006 SL500 & 2003 S430 . Night time: Hard and Fast with my wife
maybe a dumb question: what are these engine/transmission mounts look like/made off?
Old Feb 11, 2013 | 06:41 PM
Stoofpilot's Avatar
2004 SL500
Any after market mounts that are better than the OEM MB mounts?
Old Feb 17, 2013 | 08:31 PM
Wolfman's Avatar
Super Moderator
Here is one of the motor mounts. There is some fluid inside the rubber section.
These things are cheap for any car and relatively cheap to replace on 500's or 55's.
On the V12's the engine just has to come out, hence the huge labor bill (20 hours)
Attached Thumbnails Car vibrates, especially when cold. Any thoughts?-w01331718424feb.jpg
Old Feb 17, 2013 | 08:33 PM
Wolfman's Avatar
Super Moderator
Never tried anything else but OEM's but don't think that aftermarket would be any better.
This is just the cost of enjoying heavy, big torque engines
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
