SL/R230: Prior design wide body project
Old Apr 19, 2013 | 06:18 PM
  #51
Ekselent's Avatar
SL600 / SL450 (107) / E350 / BMW M5 E60 / BMW 745i (E23) / BMW X6M / Toyota Hilux 4 WD/ Honda CBX 10
Originally Posted by Chris The Swede
Just want to say that my prior design hood wont fit AT ALL on my SL65. VERY poor fitment. Cant even use it.
Chris...
I was at your thread and note that your hood is different model of hood I have.
I have had seen both hoods and I have install them also and that hood quality is not as good as Black edition. Black edition hood have more weight and it's better made if you looking "inside" of the hood. The hood frame itself it's much stronger.
I'm sure that is not due to the fitment problem... I want only mention this.
Sorry to hear about your fitment problems.
Juha
Old Apr 20, 2013 | 03:35 AM
  #52
Chris The Swede's Avatar
W222 S63L, ML/GLE350
But do realy the Black edition hood fit with the standard OEM fenders? I think that is the main problem. The Black edition fenders is higher and that makes the hood fit better.
Old Apr 20, 2013 | 03:37 AM
  #53
When it comes the the headlight cable kit I understand it is only like 2 cables that have to be moved to the right location in the new conector to make leveling work. Have a friend that did this and it works perfectly. Working on finding out wich it is.
Old Apr 20, 2013 | 03:44 AM
  #54
RaFFi ///AMG's Avatar
W124 E500 (RIP), W211 E350 (Sold), R230 SL55 (Current)
Fenders should be the same height.. just the front grill area is different. Please let me know if you get any updates on the auto leveling pins.. still trying to figure that out
Old Apr 20, 2013 | 02:45 PM
  #55
Ekselent's Avatar
Yes I think also so... first I believed that we discuss about same type
of hood.
Sorry....
Juha
Old Apr 21, 2013 | 01:13 PM
  #56
Ekselent's Avatar
Paint pictures.
Here few pictures about my car with new paint. At this pictures you can see first layer of clear coat. ( I have decide of 3 clear coat layers)
So the car is ready now and tomorrow they car going to paint al front parts so I can start to install al front parts at Tuesday.
Attached Thumbnails Prior design wide body project-img_0128.jpg   Prior design wide body project-img_0129.jpg   Prior design wide body project-img_0130.jpg   Prior design wide body project-img_0131.jpg
Old Apr 21, 2013 | 05:30 PM
  #57
Supernice color...Love the shine.
Old Apr 23, 2013 | 04:53 PM
  #58
Ekselent's Avatar
Thank you....
Here is more pictures from today .....
Attached Thumbnails Prior design wide body project-img_0137.jpg   Prior design wide body project-img_0138.jpg   Prior design wide body project-img_0139.jpg   Prior design wide body project-img_0140.jpg   Prior design wide body project-img_0141.jpg
Old Apr 23, 2013 | 04:58 PM
  #59
Ekselent's Avatar
Here is few pictures when I cut of 3-4mm of the front wall plate where the hood rubber sit.
I cut it of a little because it's easier to close the hood... it's was very tight where the rubber hit the hood.
Now I think it's help a lot with the fitment.
Attached Thumbnails Prior design wide body project-img_0135.jpg   Prior design wide body project-img_0134.jpg   Prior design wide body project-img_0133.jpg
Old Apr 23, 2013 | 06:15 PM
  #60
Thericker's Avatar
V12-Biturbo
Yup! Excellent color choice..
Old Apr 26, 2013 | 04:03 PM
  #61
Ekselent's Avatar
Originally Posted by Ekselent
Hello.
Here is the new Intercooler pump from Speedriven. I bought it last year.
It's flow about 3 times better than stock.
I'm gone install it so it's run al the time when ignition is on.
You can't use the OEM wiring if you want to use the pumps al capacity because it's to small..
Today I have install this new pump. I install a new power line also from the pump to fuse number 15. This pump consume about 8 Amp so I change a bigger fuse from 15 Amp to 25 Amp also.
Now the pump run constant when ignition is on and the wires is large enough.
Old Apr 30, 2013 | 03:42 PM
  #62
Ekselent's Avatar
Attention.... I gave wrong information.... the fuse number is 19 ( Ignition coil ) not fuse number 15.... Sorry.
Old Apr 30, 2013 | 04:52 PM
  #63
Finally got my hood today, and it turned out to be damaged on the corners.
Old Apr 30, 2013 | 05:05 PM
  #64
Same happened to my first hood. They replaced it.
Old Apr 30, 2013 | 05:07 PM
  #65
Bleh, I waited a month for this hood not gonna wait another month for another lol. Just gonna use my stock alum hood. Maybe down the line I will save up for an OEM black series hood.
Old Apr 30, 2013 | 05:26 PM
  #66
Anyone know if the R231 SL steering wheels will fit the R230s?
Old Apr 30, 2013 | 11:46 PM
  #67
Ekselent's Avatar
My first hood had also a small damage... but it was pretty small so I fix it myself. I ask for compensation and the gave me that.
Old Apr 30, 2013 | 11:50 PM
  #68
sent you a pm juha
Old May 1, 2013 | 12:17 AM
  #69
Ekselent's Avatar
sent you a pm juha
I have read it and I gave you the info you need...
Juha
Old May 1, 2013 | 03:19 PM
  #70
sl600Rtech's Avatar
sl600 and clk430
how is your project coming along? any after px available?
thanks for the pix of the fuse boxes you took BTW!!!
Old May 1, 2013 | 05:33 PM
  #71
Ekselent's Avatar
Thank you
My car is still at the paint shop... and tomorrow I think I have more pictures.
They paint my parts now and I have install the rear pumper yesterday
.. tomorrow front fenders..... so it's moving on....
Next week new wheels and tires....
Juha
Old May 2, 2013 | 12:12 PM
  #72
Ekselent's Avatar
Install pictures
Hello.
Today I have glue the grids at the both fenders and after that I have also install them.
Tomorrow next is the front pumper...
Yes... the tail pipe is not at the right position.... I have only hang them at the exhaust pipes....
Attached Thumbnails Prior design wide body project-img_0148.jpg   Prior design wide body project-img_0149.jpg   Prior design wide body project-img_0152.jpg   Prior design wide body project-img_0153.jpg   Prior design wide body project-img_0154.jpg
Old May 2, 2013 | 01:20 PM
  #73
sl600Rtech's Avatar
sl600 and clk430
i am so Effing excited for you..lol, cant wait for your project to be finished, keep posting them pix would you?
Old May 2, 2013 | 01:52 PM
  #74
Looks good Juha. Any updates on the headlight wiring?
Old May 2, 2013 | 01:53 PM
  #75
Ekselent's Avatar
Thank you.....
Yes.... tomorrow more pictures with front pumper on.....
