SL/R230: Need help with this flap
Old May 15, 2017 | 10:23 AM
fred marku's Avatar
sl 55 amg
every time I lower the hard top this flap stays up and I have to manually push it down to drop! Like a loose/broken tension spring! Need help with a diagram or a part number! Here is the pic thnx once again everyone
Old May 15, 2017 | 06:54 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
You have to buy the entire panel that the flap is attached to - it comes as a unit. The part number is A2306903125 + your interior color code. For example, mine is black so it's color code 9E44. Here's the lowest price I've found for a new one:
http://www.genuinemercedesparts.com/...23069031259e44
It's not too difficult to replace. You remove the metal trim at the top of the B-pillar, then a screw that is sort of hidden under the large flap behind the panel, and a nut that you loosen underneath, access through the opening of that flap.
Old May 16, 2017 | 09:19 AM
fred marku's Avatar
sl 55 amg
cool thnx man but I need the passenger side not the drivers side what's that part number?
Old May 16, 2017 | 07:23 PM
moretech's Avatar
2003 sl 500
Look at the other flap. There is a spring there? See its position. Is it on the flap that does not work correctly? If it is still there you might be able to rig a fix for a dollar or two.
moretech
Old May 16, 2017 | 10:23 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Right side is A2306903225 + color code.
Old May 18, 2017 | 06:09 PM
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
there are several threads using various methods where people have rigged up something to work instead of drop $300 on a new flaps.
The plastic gets brittle and crap starts breaking on them every 7 years or so (my 03 had the flaps replaced once by the previous owner and now both of them are starting to have issues again).
Old May 18, 2017 | 06:14 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I'll end up spending the $300 to replace mine. Not only is the flap hinge broken, the MB-Tex on the panel is all wrinkled. All the MB-Tex on all the rear cover panels is aging, but this one happens to be the worst one, so I'll kill two birds with one stone with its replacement.
Old May 18, 2017 | 06:27 PM
jcwright's Avatar
2005 cooper s,2007sl55
This just happens to be one of those little problems r230 owners have to put up with.the color your showing looks like stone beigh the spangler repair is a cheap fix, or look on e-bay and put in sl rear trim panel ,I think they had a stone color on the site. hope this helps
Old May 18, 2017 | 11:13 PM
moretech's Avatar
2003 sl 500
I rigged a piece of elastic to the flap spring which I got from the fabric store to the straight piece on the spring. I tied it to a large bolt/nut in the upper corner of the trunk which is visible with the lid all the way up. look way up in there. Tightly wrapped it will close the lid and act as a catch to keep the thing from blowing off the car. I did this as a safety deal do to forum messages about lost flaps but my flaps are ok.
moretech
Old May 23, 2017 | 01:45 PM
anothercar's Avatar
2002 C4 Cab, 2014 Audi A5 cab, 2017 X5 35d
pelicanparts.com is a good resource for all things MB.
