SL/R230: Anyone having problems with their SL600?
68GT500KR
It is a much better car than the two '03 SL 500's that I've had.
I agree with the "get heavy" advice. Get the name of the Zone Manager from your dealer. This is not acceptable! Also read the terms of your state's Lemon Law and document everything. Time, date, person you talked to or couldn't talk to etc etc. I would also ask for a loaner S, Cl, or SL class. Tell the owner of the dealership that his will suffice!
The SL65 may possibly be built on the line and then shipped elsewhere but if that is the case, it should only raise anxiety levels about problems with it.
The issue with the car is that it is far too complex to be fixed competently in the field. The most a field technician can be expected to do is to connect the computer, work through some diagnostics which may or may not accurately pin-point the failing component and then replace parts until it works. For problems which are not amenable to being solved by computer diagnostics, like rattles, noises, vibrations and so on, the technician is on their own and has to rely on an equivalent of Microsoft's Knowledge Base to provide hints and tips. These guys are just not up to the task of understanding the whole car in detail. No-one in Mercedes Benz understands the complete car ("I do air con but I don't do transmissions") so why should we expect field technicians to be able to?
Truth is, a car the complexity of the SL is the most complex thing - from a systems point of view - any consumer can buy for the money and supporting it in the field is a nightmare.
Under the law, you need 30 days to qualify it for as a lemon and my car was in for 29 days.... They told me that in fact it is less than that not counting the backorder of parts as all sl600 parts are special order only. so, anyone who is looking at the 600 better hope that they dont have as much trouble as me as they dont usually have the parts in stock.
Does the lemon law in your state allow the dealer to "hide behind" waiting for parts to arrive? Might be worth a consultation with a lawyer to find out what the law really says and what your rights are. Information can be power and if the dealer is not correct or exactly correct then you will have a better case.
Also, it can be important to follow the escalation procedure EXACTLY as written in the Manual concerning on-going problems. In any event an experienced lawyer should be able lead you in the right direction. Also, if you have not done so yet take the time to prepare a comprehensive timeline as to what went wrong when and what happened to "fix" the problem. Document exactly what the dealer/service personnel said. Take the time to think back to each visit to the service department and write down to the best of your recollection just what transpired. The more facts you can document from the whole 30 days and then from now on will help your case.
Good Luck and let us know what happens (as someone else might also need to know).
I have LOTS of problems with my SL500! During approx. 20 k miles it had to be serviced more than 60 times!!!! Tons of problems like SRS warning light on (more than 14 times till now), SBC failure, oil leakage from ABC system, power windows not working, keyless go problems, strange noises and vibrations from the transmission, horrible roof-noises, parktronic failure, fuel-gauge failure, driver's power seat failure, COMMAND failure (had to be replaced twice as the first one occured to have scratched monitor - apparently by the person who fitted it in the place of original one
) and many many more...Once it was in the dealership for 23 days... what is even more interesting is that they have done over 450 miles for "tests"during those 23 days...
The roof was regulatd more than 5 times now and it still generates horrible noises...
There are also some problems with seals as the wind noise makes listening to the music literally impossible over 120 mph...
The case is in court now. MB Poland stat that they will not exchange my car. We will see..... what the f*** are they going to tell?? That this is the way it should be???
Best regards
Maciek
