SL/R230: Trunk closed and locked b4 i attached power and actuator rod!!!
i had yet to attach the rod onto the ball and by accident closed the trunk. Now i have no power to the electric release and cant open with the key .
does anyone know of a way to manually lower hardtop ?
or is there a way to get into the trunk from the interior so i could get to the trunk lock and pop it open?
please help!!!!!!
thanks for the anticipated response!!!!!
There is a way to lower the roof in your situation, you will need to access the roof control module which is underneath the rear fuse box.
The rear fusebox is in (under) the storage compartment behind the right hand seat.
Can you access that?
If so I can give you details of the roof opening procedure.
Thanks Very much for the potential fix!
