SL/R230: 07 SL550 will not crank when hot
Check for good grounding of the engine, I've seen issues where a broken/corroded ground strap caused things like that, the starter would just start to engage but then it would stop, checked from the engine to a ground point and found appx 200 ohm, went to remove the ground cable at the body and the stud snapped off, was all corroded underneath, couldn't see it. Ran my own ground wire, fired right up to drive to the bodyshop and have a new stud welded in.
Ok here you go after it cooled off it started like a charm.
The new E/S63 have water cooling for the M/E as it would get baked on top of the engine. The GT it's over in the fender area to avoid that.
EDIT: Oh, and before replacing the ECU, I might would disconnect the wiring harnesses and give everything a good shot of contact cleaner. Although they do use seals on the connectors, they are in a harsh environment and could still have some small amounts of moisture or dust work in there.
