SL/R230: Roof opens/closes very slowly after hours of inactivity but gets faster afterwards
As you can see, it almost hung in the half way of the operation. Trunk lid also moved very slowly.
But, the weird part just began…
After ONE slow opening or closing operation, subsequent operations become smoother and faster. That is, my roof will open / close a lot faster and smoother after one or two abnormal operations.
Other notes:
- All my hydraulic cylinders had been rebuilt last year. Mechanics have confirmed that all struts, hoses and junctions are properly sealed and not leaking. In fact, the fluid level in the pump reservoir remains the same over past few months.
- My hydraulic pump had just been rebuilt last month. The problem existed before pump rebuilt so this problem shouldn’t be caused by bad installation. In fact we rebuilt the pump because it was deemed to be the cause of this problem. But now seems like it’s not the case.
- It is checked that no air bubble is inside the hydraulic system.
- Slow operations took about 35 secs as shown in the vid. Subsequent faster operations took about 20 secs. Faster and significantly smoother but still not as fast as a normal operation (16 secs).
- If a roof operation is NOT performed for next 4~5 hours, whether the car is running or not the roof resumes back to “slow mode”.
I once thought that there is some kind of pressure accumulating mechanism and mine failed. But mechanics said there’s no such thing.
Anyone has similar experience? Any feedback is greatly appreciated.
Having a SmartTOP module which obviates the need for holding the roof control switch and also allows the top to operate while the vehicle is in motion made having a slow roof tolerable to me.
Have you checked your struts? I found out there are 4 gas struts that carry the weight of the roof components. Hydraulics were designed assuming the 4 struts hadn't worn out. The ones on my 2004 SL55 had worn out, and from the articles, worn-out struts put added pressure on the hydraulics to compensate.
There are a few good threads on finding and replacing the struts. I just did 3 of 4.
