SL/R230: roof stuck open, trunk lid not all the way shut, need advice
The current condition is top down, truck lid 2" from closed. No warning lights. No mercedes codes on the vari roof and bar DTC. Trunk lid feels locked in place with hydraulic pressure, no up or down. I can hear the hydraulic pump running when I push the button in either direction.
I have tried pushing/pulling lightly on the lid while trying to move it. I have tried putting pressure on the flaps or "wings" to make sure the switch is engauged. I have tried resetting the window limits. Still no luck.
May be coincidental, consumer battery was changed last week. Top worked totally fine yesterday and this morning so it has been used successfully prior to this.
If you want to get it to a closed state and start there then open the trunk and there are two round plastic trim pieces, one on each side of the trunk in the carpet. pop those out and you
will have access to a 5mm allen bolt. They turn the cam mechanism that lowers the front of the trunk. you usually have to turn them at the same time if they still have fluid in them. once that is done you can
close the trunk and try operating from a fully closed starting place.
turn your key on but do not start,,, hold down the close button,,, turn the key off...it should close,,,,now use your mercedes tool to lock it.
I am sure I can also look it up, but what kind of hydraulic oil does it take? I have about a gallon of fresh CHF-11S on hand from replacing the ABC pump but not sure if that will work.
