SL/R230: Mercedes Sl
Old Jun 18, 2019 | 07:27 AM
Winston12's Avatar
Mercedes Sl
Mercedes Sl
Hi car don’t open with the key a few yards away had reconditioned PSR Pump fitted and someone said it’s the IR Radio receiver?
Old Jun 18, 2019 | 08:16 AM
speedlimit's Avatar
Administrator Emeritus
Welcome to MBworld!
Can you be more specific concerning the model and year of your car? Thanks!
Bob
Old Jun 18, 2019 | 08:39 AM
Winston12's Avatar
Mercedes Sl
Hi it’s a Sl500 2003 thanks
Old Jun 18, 2019 | 01:03 PM
chassis's Avatar
2017 GLE350 4MATIC
Welcome! Please post a photo of the SL.
Old Jun 18, 2019 | 03:11 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to R230 forum...
Old Jun 19, 2019 | 06:12 AM
sean65's Avatar
2004 SL500
Have you checked the battery inside the key? I believe it’s an R2032 battery, could be wrong.
Old Jun 19, 2019 | 07:23 AM
Winston12's Avatar
Mercedes Sl
Definitely had Machanic look at most things?
Old Jun 20, 2019 | 04:35 AM
ponchik's Avatar
SL600 2004
The battery os r2025, 2032 will not fit.
If the car opens only when you're close, its probably the battery. When you're close to the car, it opens via IR, that does not require battery at all.
Old Jun 20, 2019 | 07:49 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
I have no idea. I wasn't there...
The only infrared (IR) operation that does not require a battery is communication between the key and the ignition switch with the key inserted in the switch.
Old Jun 20, 2019 | 08:09 AM
Winston12's Avatar
Mercedes Sl
Thanks but every now and then the fob don’t correspond with the car even when I put the fob next to the door handle and have to use the key to get in
Old Jun 20, 2019 | 08:26 AM
bobterry99's Avatar
...someone said it’s the IR Radio receiver?
Be wary of any advice given to you by "someone".
The principal avenue of remove communication between the key fob and the locking system is by a radio frequency (RF) signal. There is, in parallel, an infrared (IR) signal which can lock/unlock the car and work the roof and windows.
It seems either the battery in your remote is weak, or the remote is faulty. So try another key and also check the batteries. If you look into the lens of the key and press the lock button you should see a brief pulse of light.
