SL/R230: sl500 convince battery
Old Feb 7, 2020 | 10:52 AM
njbiker2008's Avatar
sl 500 r230
what is a good convince battery for the trunk.2006
Old Feb 7, 2020 | 12:34 PM
Dudeman's Avatar
Current: '07 SL550 & '14 GLK350. Previously owned: '06 ML350, '05 SL500, '99 ML320 & '98 SLK230 (RI
If by "convince battery" you mean consumer battery, you can get aftermarket batteries, but either way, you're looking at about $300. These are AGM batteries that are designed to operate in "deep discharge" mode.
Something like this:
https://www.autozone.com/batteries-s...5_617627_25698
Old Feb 7, 2020 | 12:54 PM
imtheking's Avatar
Former R230, W220 and W221 owner
Just get one from the dealer- just replaced mine- $225
Old Feb 7, 2020 | 01:28 PM
pmercury's Avatar
member
CL
A0009823108 can be replaced with
Varta E11 574 012 068 4016987119532
74 Ah
around 100$
A2305410001
VARTA 535106052G412
35 Ah
+- 150$
Old Feb 7, 2020 | 04:26 PM
seven_out's Avatar
SL500, Miata
Originally Posted by pmercury
VARTA 535106052G412
Wrong battery. The OP is looking for the battery in the trunk.
Walmart has a direct-replacement which is AGM for $150.
Old Feb 7, 2020 | 04:59 PM
pmercury's Avatar
member
CL
Not wrong,
https://www.motor-doctor.co.uk/produ...tarter-battery
I gave replacement for front and rear
Old Feb 7, 2020 | 09:16 PM
seven_out's Avatar
SL500, Miata
The larger VARTA battery will work, but it's still the wrong one for this application. Mercedes spec'd AGM construction for the rear battery.
In addition to Walmart another good alternative is Advance Auto Parts. If you place an order online you typically get about a 20% discount, and this brings the cost of a battery from them in line with the one from Walmart.
Old Feb 7, 2020 | 11:44 PM
Dudeman's Avatar
Not to mention that Varta batteries are nearly impossible to find in the US, which is where the OP resides.
@pmercury if you're going to make purchasing suggestions you should always consider the location of the user you're making the suggestions to. Oh, and the link you posted is still for just the starter battery, not the consumer.
Old Feb 8, 2020 | 12:06 AM
ray0214's Avatar
2011 mercedes sl550, 1995 corvette
ADVANCE AUTO
AGM, exact fit exceeds OE amperage. $199 on their web site with 3 year free replacement warranty. Just go shopping on their web site... look long enough and they will pop in with a 20% and sometimes 25% discount when ordered on line and picked up in store. Only suggestion I would make is when you pick it up at store, check manufacture date. They will keep batteries on the shelf for 90 days, and, while that may be ok, I usually ask them to pull one with a more recent manufacture date
Old Feb 8, 2020 | 04:35 AM
pmercury's Avatar
member
CL
Don't dream to much with what MB pretends
they never made batteries and just relabel
and is marked as "starter battery"
battery life is standard 5 years
also, here in Europe, where I moved, the Varta is given as replacement but many other companies make them over the world
here is another one with same specs as AMG
Amazon Amazon
at least it might help some Europeen owners to get one
Old Feb 8, 2020 | 09:49 AM
pmercury's Avatar
member
CL
Duralast makes them too
5 year warranty
Old Feb 8, 2020 | 10:50 AM
Dudeman's Avatar
https://www.amazon.co.uk/Battery-35A.../dp/B00XIB7E6Q
Dude, Are you for real????
Do you even pay attention to what you're posting or maybe even the part about this thread being about the consumer battery, NOT THE STARTER BATTERY.
Here is your latest posted link:
Old Feb 8, 2020 | 01:41 PM
pmercury's Avatar
member
CL
Replaces original Mercedes Benz battery a 230 541 00 01
Just helping
BTW ; is there a "Dude-Club" with a membership ?
Old Feb 8, 2020 | 03:28 PM
Dudeman's Avatar
Just helping
I guess there's language barrier here, or you're unclear on the R230 dual battery concept, and the fact that the two batteries ARE NOT THE SAME.
R230 Dual Battery system
The battery part code you posted A 230 541 00 01, is for the STARTER battery, not the auxiliary/consumer battery in the trunk (or boot if you prefer). That battery is a 12V 70Ah, part# A 004 541 8601
File Type: pdf
Old Feb 9, 2020 | 06:06 AM
matk's Avatar
R230 350SL
Can you guys please stop fighting? It’s really boring for everyone else.
There’s plenty of info for the original poster to look at already, and I’m sure they’ll post again if they haven’t got the info they want, or want to clarify which battery they refer to?
if you really want to get into a debate about the accuracy of posts why don’t you do the respectful thing and do it between yourselves via private messages rather than out in public? Alternatively if you feel that strongly about a post why not just contact the Mods and let them sort it?
Old Feb 9, 2020 | 09:16 AM
pmercury's Avatar
member
CL
you are right
