SL/R230: Plunger sensor
Old Mar 2, 2020 | 10:31 PM
Bohnenblust1's Avatar
SL 55
Plunger sensor
I have a 2003 sl55 with the blue abc warning for a rear left plunger sensor. The live reading is 255mm. When I switched the sensors left and right the sensor worked on the right side. I am getting 5v at the sensor and the signal wire has voltage out.
does anyone know the wire path and termination of the signal wire?
Old Mar 3, 2020 | 02:40 AM
pmercury's Avatar
member
CL
Do you have Xentry/Das ? if yes PM me I can do some tests and find out in 10 min by remote that way you learn how to I diag 2 per month
if not wait for people here that work without, they love struggling ( joking )
Old Mar 3, 2020 | 08:23 AM
pmercury's Avatar
member
CL
got your PM, nice you borrowed a Xentry
Old Mar 3, 2020 | 09:32 AM
seven_out's Avatar
SL500, Miata
...does anyone know the wire path and termination of the signal wire?
The signal wire is yellow with a grey stripe, and it goes directly to the ABC controller (N51) passing through no intermediate connectors. At N51 it terminates on socket #17 of the large connector (pictured). I imagine you'll check continuity between that point and the sensor connector and inspect the quality of the electrical connection at N51.
Old Mar 3, 2020 | 10:45 AM
pmercury's Avatar
member
CL
thx! doing diagnostics first
Old Mar 6, 2020 | 06:40 PM
SL 55
Turns out the plunger sensor is bad.
Anyone have a source for used ones or rebuild? Hate to buy a whole strut just for the sensor.
Old Mar 6, 2020 | 08:51 PM
pmercury's Avatar
member
CL
deleted wrong picture
but you have the link now enjoy !
Old Mar 9, 2020 | 09:27 AM
nishboo's Avatar
W124, W126, W140, W220, W222, R129
I have the same issue with the front left. I did the rodeo twice. I may change fluid before changing strut. I heard that may help. May be worth a shot in your case as well.
