SL/R230: Clocks don’t match up
Use the steering wheel to get into the time function. One would think you would use the center display, but you need to use the steering wheel instead.
Once you find the time submenu, change the time to manual
At that point you can save / exit / go and update the time
Then go back into the time submenu and set back to automatic
It's crazy... and super (un)intuitive... and for whatever reason, google searches won't typically provide an answer. Hope this helps.
1) Everything is going to be performed from the steering wheel
2) Start the car. Go to Settings (on left) To reset: Press reset button for 3 seconds (on right)
3) Press the down arrow (you may have to press up or down here) to get to
4) Time sync. with head unit (on left) + / - On / Off
You're doing this to "break" the head unit's stranglehold on your ability to set the time
5) Press the down arrow to turn Off
6) You may have to exit here
7) Go back in and you should see a Set time Minutes (on left) + / - HH MM (on right)
8) Set the minutes using + / - buttons
9) Set the hours using the + / - buttons
You should see the clock on the center COMAND unit change as you do this
10 Get back to Time sync. with head unit and set back to On
11 Exit out
Hope this helps.
David
11 Exit out
Hope this helps.
David
Many thanks to both of you.
Thx for the replies, however in my 2003 r230 I could not find the ‘time synch’ I will look again but am unable this far.
Also at times when I set the time through command module the month, date and year are sometimes not highlighted. And if they are and I reset to the present time etc, it reverts back to 12, 20, 2000nafter a few minutes of driving.
I am at a loss.
Bill M
I am at a loss.
Bill M
vs the 2003 menus.
Internet searches (it's always true right) indicate that the only way to reset the non- COMAND heads are the SDS, dealer, or doing the midnight process...
Sorry for saying this... but Mercedes botched this pretty big time... I don't think it's cool that one can't set a clock...
vs the 2003 menus.
I will try the '12:00' trick and also leave both batteries disconnected to see if this works. Still welcome any guidance on how and where the menu could be enabled if anyone knows in SDS.
