SL/R230: SL 500 (R230), ABC Repaired, Now driver side rear will not lower
My car has been laid up for 2.5 month with a variety of problems. My current problem is that after the car has had new ABC hoses, and the valve blocks refurbished and working, and new accumulators put in. The driver side rear will not lower. The vehicle appears to think at max height it is level.
s their anyway to get the ride height sensors to default back to factory?
My garage has attempted to reset the the values for the ABC. The front resets fine. When they get to the rear, the program tells them they are out of specs and does not allow them to put in new specs for the ABC.
Any help is greatly appreciated. Where I am it is almost time to put the car away for the winter.
Regards.
If you go into ABC actuations, you can control both of these valves manually. If I recall correctly, the blocking valve terminology is a bit confusing, on being open (unblocked). If you turn the blocking valve off (F4), the strut should not move, even if you actuate the control valve. If you get movement, either the valve is leaking (most likely), or it is stuck open. To test the control valve, turn the blocking valve on (F3, unblocked) and actuate the control valve in each direction (F5 & F7). The corner should raise and lower with about equal speed. Next, put the valve in the neutral position (F6), the strut should not be moving. Any movement with this setting means that you have an issue with the control circuit, most likely bad o-rings on the valve. You will also be able to see the actual current to the control and blocking valves. The blocking valve should be within range, the control valve should be near zero with the car running and stationary. If you have a control valve leak, it will be fighting that leak and not in the neutral position.
You could try a rodeo or a filter procedure in case the issue is contamination, but I think you will end up pulling the rear valve block again. You can also look at the strut plunger and ride height sensor values and see if they make sense and, of course, start by checking ABC codes.
Mike
If your car does not sag, then the blocking valves are okay. Despite having working blocking valves, your car is able to jump because unlike the control valves, the blocking valves unconditionally remain open for a brief time after the engine is switched off.
There may be a check valve malfunction in similar fashion that can not let fluid out from struts too.
In both case, control valve, even was function as normal. Can not control the height.
Try applying voltage to the block valve solenoid directly, monitoring any click sound from valve. Or any current change from this dc supply. This will identify the solenoid situation.
Same method can apply to all solenoids of all/any valves, basically back to 60’. That manually control without computer’s help.
Mike
I wouldn't think it possible for a valve spring to break, yet kbob999 reported finding one a while back. More recently, a friend had the exact issue as the OP, and in his case a valve return spring was missing -- the functional equivalent of a broken spring. The valve block had been disassembled by a previous owner and then reassembled without one of the springs.
Theoretically I suppose the suspension may jump as a consequence of an errant input to the ABC controller, but that seems almost implausible to me. Still, if Star Diagnosis is available, as others have mentioned I would look at the current to the control valve of the affected strut and ensure that the controller isn't causing the action. A positive (+) current to the control valve extends the strut to raise the car, while a negative (-) current to the valve retracts the strut to lower.
