SL/R230: ABC 2 front valve block leaks externally from front side
On my 07SL, front ABC valve block leaks from 17mm plug ( bolt or plunger) that is on the front side of the block. I noticed a piece of damaged O ring that comes out of the block’s opening. Attached is the screenshot of the valve block for the reference, I circled in red the place of leakage. Does anyone know what is the purpose of that 17mm plug or bolt? I know that ABC 1 blocks are rebuildable but not ABC 2. I want to pull it out to see what kind of O rings are there but wanted to consult with you first. Thank you, Vadim
Is the thing in your photo mounted in front of the front wheel or behind it?
https://www.ebay.com/itm/ABC-Ventilb...AAAOSwtYJbqOFs
I know this is an old post but did you ever fix it? I had the same leak on my 2008 SL65 front block and just pulled it out, matched up the o-ring and replaced it. But my car is now starting to sag after sitting for very long time at driver's front so I suspect the valve block needs to be rebuilt or replaced. Have you found any options for rebuild of the gen 2 valve blocks?
DM me if you need more information.
