SL/R230: Rebuilt the front valve body but the car does not lift the front
I put new oil in the reservoir. I wonder if the problem is due to the system full of air..! Any wise hints to resolve this will be greatly appreciated.!
Check the reservior fluid level when the car is off, then when the car is running. The dipstick has marks for both levels.
If the level isn't dropping to the correct level when the car is running, try applying some air pressure to the reservior while the car is running. Mercedes-Benz workshop information specifies 14psi; I've done this using a bicycle tire pump. You can do it using an air compressor, just be careful and don't go overboard with pressure.
Any hints!
Big thanks!
