SL/R230: abc error
Old Jan 21, 2022 | 06:57 PM
imtheking's Avatar
Former R230, W220 and W221 owner
abc error
2003 sl500
Drove to work, walked out 8 hours later and saw puddle of ABC fluid on the ground (front)
Opened the hood and saw the dipstick for the reservoir was dangling and abc fluid and gotten all over the reservoir and surrounding areas. Put the dip stick back on properly and started driving. Got white abc error and minutes later followed by red abc error.
Before I drop this off to my mechanic I'm thinking I fill the reservoir back up again. Maybe light came on because of low fluid?
Old Jan 21, 2022 | 07:06 PM
cdk4219's Avatar
95 SL600
You would be the luckiest r230 owner in the world if it’s that simple.
Old Jan 22, 2022 | 12:09 AM
Gene Fiorot's Avatar
SL500
I am thinking you need to start reading threads regarding Coil Over Conversions. A smart way is to do that. But all of that is up to you. keep us posted.
Old Jan 22, 2022 | 09:33 AM
cdk4219's Avatar
95 SL600
That seems to be your problem.
Old Jan 22, 2022 | 11:20 AM
SL500
How much does a accumulator cost ?
Old Jan 22, 2022 | 12:38 PM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
I bought one from FCPEuro in August for $110, but I see that it is up to $150 now.
Old Jan 22, 2022 | 01:03 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
Yes definitely fill that reservoir and do not drive the car if the leak is other than a faulty dipstick seating. Your pump will be ruined without proper levels in the reservoir. Major $$$$ to replace. Consider a flat bed tow.
Old Jan 24, 2022 | 08:50 AM
imtheking's Avatar
Dropped the car off Saturday. Fluid was a little below the MAX line BEFORE start up. I to was thinking accumulator. Will keep you guys posted
FYI- I bought the car with Strutmasters installed. Worst ride ever. I spent money and put ABC back on
Old Jan 28, 2022 | 04:52 PM
imtheking's Avatar
They did a rodeo/ABC flush and changed the filter. All is good (for now)
$400
Old Jan 29, 2022 | 04:12 PM
wizee's Avatar
'07 CL550
$400
Keep an eye out for any ABC warnings when driving over bumps. You’ll get momentary low pressure errors when the struts need fluid rapidly if an accumulator is bad. It wouldn’t surprise me if one of your accumulators blew and put a bubble of nitrogen in the system that caused fluid to spew out of your reservoir. Driving with bad accumulators also increases the risk of blowing hoses or damaging struts. ABC accumulators tend to need replacement every 10-15 years.
Old Jan 29, 2022 | 05:01 PM
cdk4219's Avatar
95 SL600
All good “for now”
Old Jan 29, 2022 | 05:03 PM
MikeJ65's Avatar
Exactly what wizee said. You can run the pressure drop on shutdown test to check accumulators. My experience is that a bad from accumulator will throw ABC warnings on bumps, but the rear is not as likely to. Blown accumulators add high stresses to the system, they were put there for a reason.
Old Jan 30, 2022 | 11:26 AM
imtheking's Avatar
Got it- that what I was initially thinking- blown accumulator. But they did a flush and all good. I will keep an eye for errors when going over bumps.
One thing I noticed is that there is pully noise coming from the pully connected to the pump. After the car warms up, it goes away. Another thing I have to look out for now. Wasn't there when I took the car in. Not sure what they did. It has been very cold here in DC- 15 degree nights so hopefully that had a role to play in the noise?
I now make it a habit to start the car once a day to get the juices flowing. Also bought a cold weather extension cord so I can run it to the the trickle charger (50 feet away from closest outlet).
Old Jan 30, 2022 | 01:13 PM
cdk4219's Avatar
95 SL600
I would guess a bad accumulator would rupture and the gas that’s in it would cause the “air” in the system as well as displace the hydraulic fluid, pushing it out through the reservoir like you had.
My guess is that filling and rodeo got the “air” out and there is no more faults from that. The accumulators absorb the shock from bumps , the system doesn’t have a fault code for bad accumulators.
As above, the warning will come on when bumps are hit. If the accumulator is bad, the rest of the system is taking the shock load. I would take the advice above and get the leak down test done to rule this out.
