SL/R230: Fuel gauge showing low fuel but full tank?
Old May 20, 2022 | 08:09 PM
imtheking's Avatar
Former R230, W220 and W221 owner
2003 SL500
started the car this morning and it stated I’m low on fuel. I know that’s false because I had a half a tank yesterday. This has happened two or three times now where the fuel gauge would show that I have no fuel but then after 10/15 minutes of driving or shutting the car on and off, the gauge moves to the correct position
car drives and starts fine
help?
Old May 21, 2022 | 08:44 AM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
Probably either a sender going bad or bad communication with the rear SAM. The tank level is read by the rear SAM and then sent to the cluster via CAN message. I believe that the cluster defaults to empty tank if it doesn't get updates. If you have access to a scan tool, check for codes and check the fuel level actual value in the rear SAM.
Old May 21, 2022 | 03:13 PM
imtheking's Avatar
you’re the greatest. Thanks
Old May 23, 2022 | 10:29 AM
brucewane's Avatar
2005 SL600
If there are no helpful codes or data, something else to check - the R230 has a known problem where a baffle inside the gas tank breaks loose. The usual symptom reported is that you hear it clunking against the side of the gas tank. I've never seen it reported that it caused a problem with the fuel level sensor, but it seems like it could if the loose baffle prevented the float from operating properly.
Old May 23, 2022 | 02:10 PM
imtheking's Avatar
Thanks Batman- I don't hear clunking. Car was fine today and the gauge was working properly. Something is going south and I think I'll wait until it's dead and not working anymore. Only had this issue twice in the 20 times I've driven the car this year
Looks like the sender is in the trunk and somewhat easy to replace
Old Jun 30, 2025 | 11:22 PM
KingWeston's Avatar
2017 GLC 300 Mercedes Benz
Hi sorry to bother you I have the same car with the same issue over a 3 months now but I don’t know what’s possible cause I bring it to mechanic but they keep telling many codes which I don’t understand am thinking it maybe the SAM or the sending unit but to know if it’s the SAM how can I test it as it’s the only problem everything else works and I don’t know what’s possible cause fuse it use
s
Old Jul 1, 2025 | 02:27 PM
MikeJ65's Avatar
In your case, the fuel level is read by the fuel pump control module. If there are level sensor codes in that module, I would start with Option 1 or 2. The reason that they gave you two options is while the sensor is available from Mercedes, an entire aftermarket fuel pump assembly is cheaper and quicker to replace. There is also a chance that the wiring between the sender and pump control is faulty, or the control is faulty. This is whey they have option 4, in case they need to check wiring, etc.
If you have no codes in the fuel pump module and the module has a fuel quantity that can be read on diagnostics, you might have an issue with the cluster or CAN (network) issues. This would be harder to diagnose and more expensive to fix, but it is the less likely case.
Note: The quoted labor rates are very reasonable, parts markup is 100% or higher.
Old Jul 1, 2025 | 02:32 PM
KingWeston's Avatar
ok I see I bought and installed a new fuel pump model that I bought from Mercedes thinking it was the issue but unfortunately it wasn’t that case so I assumed it something else maybe the level sensor or something these list I got from the mechanic so in a case he’s not sure as those probably faults is what he got in his case
Old Jul 1, 2025 | 04:35 PM
MikeJ65's Avatar
Didn't the new pump include the level sensor?
KingWeston's Avatar
the pump module not the pump I didn’t check the pump only change the module
Old Jul 12, 2025 | 12:40 AM
KingWeston's Avatar
the new pump doesn’t comes with a fuel level sensor I had to use the old one I change the pump today thinking it’s the issue but still same problem
