SL/R230: Looking for a diagram of interior parts - '05 SL600
Several items inside of my 2005 SL600 need to be replaced.
Inside strip at the base of the back window
Trim above door window on both doors
Both of these look like they have shrunk and become wavy over the years.
Hopefully a diagram will have parts number.
Removing the roof liner requires unfastening four or five hexbolts on its front end. Next you carefully pull the liner out, this will probably break many if not all of its plastic clips, which can be dealt with later. Likely culprit: front lock cilinder leaking oil.
roof half open, trim part NOT installed
roof half open, trim part installed (laying there)
Trim part, notice factory holes to secure item once installed
https:/nemigaparts.com/cat_spares/epc/mercedes/1/fg/230479/65p/79/055/
Tried for the same angle as your picture. This is a piece metal you are missing.
yes those are my glasses on the bottom left corner
