SL/R230: need to change ABC fluid and Conv. top fluid
I'm no fluid expert, only what I have picked up on to try and keep this one in decent shape. The chemicals in the fluid will break down over time. The tubing that the fluid runs through will leech out some of the "stuff" that it needs to properly work after years. If it has been sitting or in use, it's a time thing. Have them check for leaks in all 4 struts, you might be able to get out ahead of a failure if you get them replaced before they leave you stranded. There are rebuilds of these and aftermarket ones that work really well for much less than an OEM unit. If one does fail, DO NOT DRIVE IT. Pull over right away and have it towed somewhere. Driving it even for a short distance could easily double your repair costs. A tow will be much cheaper.
Also, there is a smaller micron filter out that picks up more metal shavings for these now, I would ask about that. I have also heard about one that is magnetic, which I assume would help to pick up flakes that may end up in the system.
If you plan on doing it yourself, you might want to consider pulling all the old hardware out. (or asking the shop to) Could save you about a hundred pounds or so. These bad boys could stand to go on a bit of a diet, every little bit helps.
https://rebuildmastertech.com/merced...onversion-kit/
It comes with the power steering pump you need. If I were ready to pull out my ABC, I would go with this kit.
Another essential for new owners planning to keep their ABC is to inspect all the flexible lines for weeping which is a tell-tale sign of hoses on their way out.
