SL/R230: 05 SL500 no start
So, New Years I bought an 05 SL500 red battery light was in the dash, seller told its been sitting for a while it will go away after its driven a while,on the way home stopped to get something to drink,
I had to jump start it to get it home and its been in my garage since. I have replaced the consumer battery,starter fuse under passenger floorboard, starter relay in front SAM, alternator, and starter.
Still nothing. This is my first true MB so if you have any suggestions, or tips it would be greatly appreciated. One more thing. I am only reading 9.8 volts coming out of front SAM.
I put a bosch battery in a Porsche that I rarely started, and it went bad. They are designed to be sent through charge and discharge cycles. I charged both batteries periodically on my project car. Now I am just charging the consumer battery pretty often, when I don't run it and use some juice.
I would install new spark plugs.
The front battery is the starter battery. The batteries plus guy said it needs to show more than 12 volts before you start the car. 13 volts is OK. I found a great deal years ago at Walmart online on a Stanley 15 amp re-chargeit that indicates FLO when a battery is fully charged. U can check the voltage any time. If the rear accessory battery shows less than 12 volts, it can impact numerous functions... maybe starting. Of course you must clean/polish the battery terminals with a wire battery brush.
If you have 12V and ground, relay should be clicking when you try to start. If that is happening, you probably have a bad starter solenoid, bad starter, or wiring issue.
Unlikely that the alternator is causing your no-crank issue. Most alternator issues are caused by the regulator in the alternator anyway.
Have you taken out the starter relay (green one on the RHS fuse box) and shorted the contacts? Or take the cover off the relay and pushed the armature? The engine should crank.
That relay has a reputation for failing, with arced contacts. I would at least take it apart and inspect it.
Have you tested the starter circuit by bridging 30 and 87?
That's a quick way to rule out the starter solenoid and motor.
Yes, but that is just to test the starter circuit, but it sounds like you're not getting the relay to engage. So, do the tests mentioned earlier.
Easiest way to check the starter and solenoid is to clip the cover off the relay and (with the ignition off) push down on the armature which will engage the starter solenoid, then the starter motor. If she cranks vigorously then the starter is fine.
I did not know the front SAM was powered by the rear battery, that really helps.
The rear battery was at 12.3v the last time I tried to start it. I keep the batteries unplugged, and on charge until I get a chance to work on it.
What I mean by coming out of the SAM is there is a power cable that clips down in the front of it then another plug that leaves the rear, thats where I have been checking voltage.
Even better yet... Whene taking the cooling hose loose to get alternator out I lost a little fluid, did'nt think any thing of it.
Turns out it's hydraulic fluid, and I can't find exactly where it's coming from. So I already have my next project lined up.
Thank everyone for your comments and suggestions, it really helps alot!
Even if pretty flat, you should still hear the solenoid on the starter click.
Before changing the starter, I would test it by shorting the two big copper terminals on the motor, with a thick jumper cable. The starter should crank.
You say it was changed recently. First step: inspect all the connections down there. Maybe the lead to the solenoid 'fell' off?
I've lost count of the number of times I have had to clean up after 'expert' mechanics bodged jobs. It is just woeful and tedious, paying someone for work, and then having to do it yourself again, properly.
at both starter and solenoid. I know there is a way to bump the starter, just unsure what to bridge. I will try today, the manager of the shop I took it to is coming to my house to confirm. I was a bit upset because they had it for almost a month and still it sits in my garage.
Now I'm wondering if the incline has anything to do with it starting.
Then it's sure to be the starter. Even if you can knock it into action, do you want to be stuck with a suspect starter? Best to just replace it as they're available and not too pricey, but I don't know the cost of a genuine.
But it was already replaced, so maybe you can get it under warranty.
there was several functions that were turned off, including starter, and EIS. Soon as I seen the ignition switch I knew it was a Mercedes issue. Sitting too long with no power, im not sure? It looks like the car needs to be reprogrammed.
All Mercedes vehicles of this era have multiple connections for diagnostics. It is possible that you have a pin pushed back in the diagnostic port or some other issue reading some lines. Some modules have direct connections with the diagnostic port, other have indirect communication via CAN through another module, so CAN communication is also important. The EIS does fail and it is possible that yours is bad, but with your description of the problem, I think you have something else going on.
