SL/R230: 2005 SL600 - Cost to replace front roof lock cylinder
What should I expect to pay my independent shop to replace both sides?
I called them and am in shock!
$3,500
The posts before this one tells you the solutions very clear. Other posts show step by step on how to rebuilt.
Mine caused me an expense of $10. I slitted the liner trim and glued back to a neoprene strip! Works for me!
As mentioned here, there's quite a bit of DIY parts and guidance available if you're willing and able to give it a try. TopHydraulics.com and CabrioletHydraulics.com both have rebuilds available. There's seal kits available too - definitely cheaper, but IMO paying an extra $60 or so to have a professional do this job is well worth it. For that small amount it's not worth it to me to give it a try and have to deal with the inevitable learning curve, and possibly fail.
Otherwise, you might try searching for another shop that is known to work on convertible tops. Not necessarily a Mercedes specialist - the R230 top mechanism isn't all that different from most other power convertible tops, almost all of them use hydraulics. So you might look for a shop that specializes in vintage/collectable/customized cars - they might not handle convertible tops themselves, but they will likely know someone in the area that does.
The biggest complication in repairing the R230 front cylinder is the headliner - the clips that hold it in are glued to the headliner, and they often pop loose when the headliner is removed. Be careful not to lose any of them, as they're not available as a replacement part. I think some people have made replacements using 3D printing. Epoxy them back in place and you should be good to go.
opened the roof about 10 inches to expose the Torx screws securing the headliner
Removed the headliner
Closed the roof completely
Removed the three T30 bolts securing the hydraulic cylinder bracket
Removed the C-clips and pins in each end of the cylinder to free it from the bracket
clipped the zip ties holding the various lines up
brought the cylinder outside the car and it will hang by the lines along the outside of the door (drivers)
brought a stable chair outside and placed next to the door
clamped the cylinder to the top of the chair securely
drilled a small hole in the top of the cylinder to access the C clip
popped out the C clip
pulled out the piston
removed damaged U ring
installed o ring
cleaned headliner thoroughly to remove hydro oil
put all back together
works perfectly.
Took about one hour
Note that I did the repair with the roof fully closed and locked and it worked fine.
Thanks; that sounds plausible. But the job is easy and only takes an hour, so if it lasts a couple years I'm fine with doing it again. Costs are negligible. Also let's not forget that the U-ring failed in the first place, necessitating the whole routine. So they both fail, perhaps one lasts longer.
Are there any quick inspection points (where to look for moisture/puddles) for leaks for the next three (two frame locks and the rear trunk lift)?
https://mbworld.org/forums/sl-class-...ispreloading=1
