SL/R230: Top problems on 2007 SL 55 AMG
Old Sep 18, 2023 | 01:34 PM
steevo9k's Avatar
2007 AMG SL55
All of a sudden, my top stopped working!! When the button is pushed, the windows start to move, but then stop and there is a noise of a motor running in the right side by the rear window. I did have to jump the car off because it sit to long without being cranked. I had Oriellys check the rear battery and it was good. But his device wouldn’t show how much charge was is in. Could that be a possibility?
Old Sep 18, 2023 | 04:05 PM
Abebundance's Avatar
2007 Mercedes SL55 AMG
What's the problem with the roof?
Old Sep 18, 2023 | 07:05 PM
MikeJ65's Avatar
'03 SL55 Black, '03 SL500's Aegean, Mars Red, Tazanite, Alabaster, '11 S550 Flint Gray
Will the right rear window go up/down with the switch? It sounds like you have a bad regulator or gearbox and the motor is just freewheeling. Windows must be functional, normalized, and lowered before the roof will move.
steevo9k's Avatar
2007 AMG SL55
It won’t stow away. You hit the button to make it fold back, but all that happens is that the windows move down a little, then go back up and everything stops. Now, the trunk goes up and down no problem which tells me the hydraulic system is working. So I’m hoping it’s just a sensor or something. The flaps on the trunk lid are fully closed, so unless that switch is messed up, that’s not the problem either. ??
Old Sep 18, 2023 | 07:08 PM
steevo9k's Avatar
2007 AMG SL55
Mikej65, no, windows do not go down at all. It’s weird because everything was working perfectly before I jump started the car. Maybe coincidence, who knows?
Old Sep 18, 2023 | 07:56 PM
as.thompson's Avatar
Veteran: Air Force
S550C4, Porsche Cayenne
If you had to jump start the starter battery, maybe your systems battery (in the trunk) needs to be charged or replaced. A bad systems battery causes all kinds of bad behavior in these cars.
Old Sep 19, 2023 | 07:07 AM
steevo9k's Avatar
2007 AMG SL55
I did go by Orielys and had the battery checked and it checked out good. But apparently he didn’t know how to use it because he couldn’t tell me how much charge was in it. I will charge it and go from there. Thanks for the response!
Old Sep 19, 2023 | 10:55 AM
MikeJ65's Avatar
Have you tried normalizing the windows? Pull up on switch to close front window, hold for a couple of seconds after it is closed (do this even if it is already closed). Release and reengage switch for rear window, hold for a couple of seconds after it is fully closed. Do the same for the other side.
Old Sep 19, 2023 | 11:41 AM
steevo9k's Avatar
2007 AMG SL55
I will definitely try that Mike!!! Thanks!!! I will let you know if that works.
Old Sep 19, 2023 | 08:10 PM
Tom Manning's Avatar
2005 SL 500 R230
FWIW if you disconnect the battery then reconnect, then open the roof, all four windows will normalise first automatically before the roof opens.
