renncoder
close
- Join DateJan 2003
- LocationCedar Park, Texas
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive2013 Porsche 911 Carrera 4S, 2004 SL55, 2012 Lexus IS250, 2021 Toyota Highlander
Liked:18 Times in 17 Posts
So today my 2004 SL55 decided that the steering wheel would not go up and down. Only in and out. I can hear like some kind of gear has broken and is clicking. Anyone ever taken the mechanism that controls the steering wheel apart before?
There is a coupler from the motor to the gearset that is usually the problem. Order one and replace it even if you have another problem. The job is not real fun because you have to contort yourself into position to work on it. Not difficult though.
renncoder
close
- Join DateJan 2003
I'm guessing this? https://www.ebay.com/itm/176339831727
203-462-06-78
renncoder
close
- Join DateJan 2003
Quote:
Yep. After watching a few videos I see what was meant by coupler. Originally Posted by MikeJ65
203-462-06-78
renncoder
close
- Join DateJan 2003
I'm still trying to figure out how to use WIS so I'm guessing I just need to remove that metal plate at the bottom of the steering column and I should be able to see the broken coupler at that point?
There is a pivot bolt with a clamp nut that attaches the column to the tilt gearbox. Remove it so that you can drop the column then take out the four bolts that attach the gearbox. That allows you to remove the gearbox, replace the coupler, and put everything back together.
Frederick NL
close
- Join DateMar 2018
- LocationNetherlands
- Vehicle(s) I drive2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
Liked:260 Times in 223 Posts
Reading this, I do hope mine won't give up, ever. The piece looks sturdy enough.
ExploreIt is typical Mercedes. The gearbox mechanism is machine tool quality, way overengineered. Then they put in a 10 cent plastic coupler for a failure point.
Currently Active Users (1)
