SL/R230: Problems with heating system in 2004 SL 500 r230
I cannot get the heating system to work. I have read the Owner's Manual and tried all sorts of ways to both manually and automatically set the cabin temperature. Nothing even slightly warm comes out of any of the vents. I have even tried the residual heating unit/motor engagement.
The hose from the block to the auxiliary pump is hot as well as the hose going out the auxiliary pump towards the firewall. I can hear the motor running. This is a new aux pump. Is there another control/servo/valve that is supposed to open to direct warm/hot water to the heater coil? I did replace the radiator and properly fill the radiator/coolant overflow tank with the proper concentration of the approved blue coolant. The only thing that may be of interest is that there is currently no refrigerant in the A/C system because it had to be evacuated to change out the radiator and condenser.
I hope this is something obvious that I am missing.
Any comments, help, or descriptions of similar problems with be appreciated.
Robert
Once you eliminate everything else, you have to consider the heater valve.
If you look for this problem on YouTube, you will find several vids about accessing the heater valve by British guys who remove the entire wiper assembly. Fortunately for left hand drive cars, there is a likely simpler way where the windshield cowl and wiper assembly/motor do not have to be removed. Instead you pop out the pseudo-firewall plate behind the engine by removing 4 bolts.
Personally I have removed the cowl and entire wiper assembly for a different reason and it is a pain. At that time I did not know about removing the pseudo-firewall plate. So, I haven't done that yet personally, but it appears you only have to remove its 4 bolts, 2 on each side, pop off the hood weather-stripping and yank the plate up and out. You then have access to the heater hoses, the heater valve, the A/C lines, wiper motor and such.
Hopefully others here have simpler solutions.
EDIT: I no longer think that removing this firewall plate is a possible way to access the heater valve. At least not simply. See my post below.
Last edited by mrvedit; Jan 21, 2025 at 06:21 PM. Reason: Retracting my suggestion
Can you give any direction of just where and from what angle to approach those four bolts?
https://www.benzworld.org/threads/in...#post-18144033
One of the lowest cost fixes you can do on an SL!
Anyway, here is one of the 4 bolts. Another is about 8" directly below it. And then mirrored on the other side. HOWEVER, I forgot some details which complicate this...
First, there are two bolts in the rear of this plate which hold the wiper assembly in place. Might be easy to remove, but might then be difficult to replace if the assembly moves; might have to at least remove the lower windshield cowl.
In the following pic with the engine removed, I see two more possible bolts on the left side, highlighted in yellow. Some of the spots which look like bolts are actually just push-pins to hold the felt lining in place, but others might be bolts.
Also, on my SL600, the engine harness went through this plate; no idea if your SL500 is that way too.
At this point I'm think you would need to remove the windshield cowl to see where everything is. I think there will be enough working room on the right side that the wiper assembly will not be in the way.
The two possible bolts, in yellow circle, give me pause that removing this plate would work for you. It might even hold the heater valve. (Ignore the red arrows, that was for something else.)
I confirmed that the 2 heater hoses to the heater radiator were not getting hot when the heater valve was activated. I replaced the heater valve/motor. A few comments regarding that. I did have to dis-assemble all the components in the battery area, The battery tray, remove the wipers (both sides) and the plastic covering. There may be some short cuts but I felt it best to remove these thing to prevent any damage and to better access the valve. The valve has four heater hoses attached and all are attached using spring clamps. Those are very difficult to get to. Three of the four nipples just broke off in the process. This actually made it easier to get the clamps off. They broke because they were brittle from age - probably the original valve to the car. Care was attended to insure that no broken pieces fell into the heater hoses.
I replaced the valve/motor with regular worm/jubilee claps in stainless steel. This was much easier and will make easier service should this problem arrive in the future. Upon running the car the and setting the system to max heat all four of the hoses got equally hot.
So here is the problem: This did not effect the heat in the car thru any vents/outlets at all. I connected to my iCarsoft MB II Version 11.80. In the AC menu I found all sorts of codes relating to the faulty communication with the baffle system. That list follow at the end of this post.
I used the copy of the fuse/relay diagram that someone posted that came in their trunk near their spare tire. I could find no relay or fuse that corresponded to the air diverting/baffle system. I have checked all fuse/relay box locations and there is no sign of previous water contamination.
So suggestions anyone?
From iCarsoft:
Communication error of AC bus with component B 31/1
M 16/27 space diverter flap actuator motor communication fault
M 16/21 fresh air and recirculated air flap actuator motor communication fault
M 16/13 left defrost nozzle flap actuator motor communication fault
M 16/14 right to force nozzle flat actuator motor communication fault
M 16/15 left foot well flap actuator motor communication fault
M 16/16 right foot well flap actuator motor communication fault
M 16/23 air flap actuator motor left center vent communication fault
M 16/24 air flap actuator motor, right center vent communication fault
M 16/28 left blending air flat position motor communication fault
M 16/29 right bleeding air flap position, motor communication fault
M 16/25 air flap actuator motor, left side vent communication fault M 16/26 air flap, actuator motor, right side vent communication fault
Would you please comment on my entries #7 and #8 on this thread? I was considering a starting point of just removing the unit and checking/cleaning the contacts in the pin multi-connectors.
P.S. I am not sure if I did the tagging correctly above so as each of those three members will get a notification. Any comments or help from anyone in that area will be appreciated. Thanks again.
So that removes the first fault on my list above but all of the other faults regarding the flaps still persist.
P.S. I enjoyed the conversation the other day.
So I offer this as a warning to all. When you reconnect this device make sure that one of the last things you do when reinstalling the center console is to check to make sure that that plug is in place.
