SL/R230: Alignment Issues
Any thoguhts would be appreciated.
here's the link which may be helpful to you.
http://www.mercedes-benz-usa.com/sl_class.php
What reason did the dealer give?
It sounds severe. Have you thought about rejecting the car on the grounds of being unstable?
Although you shouldn't need grounds when spending so much money!
Give the dealer hell.
Good luck!
I have then taken my car to a known flat area and found that it goes perfectly straight when the steering wheel is left alone.
Just a tip in case you may be having the same issue. You'd be surprised if you stand back and look at a road how slanted they can be. Most are especially in areas where there tends to be a lot of rain.
Good luck.
My old car never never did this on the same roads (or if it did, it was to a much lesser extent that I didn't notice). I think the extra weight and the larger sport tires on my SL grab/feel the road better which results in the "pulling" to every contour of the road.
After reading the Pasi50005's initial post, I don't think his car applies to the above. His case sounds like there is actually a problem, but for the many that I see at this forum who mention the "pulling problem"; I think this could be the reason.
Just a thought.
Will let you know if this fixes the issue.
I don't agree with the low pressures that most manufacturers specify as I know that product liability is as much an issue for them as is handling and tire life. I have owned many different types and brands of vehicles over the years and have pretty much used the same pressures I'm using now. I've always gotten acceptable life from the tires for the conditions they were subjected to, and at the same time been satisfied with the handling they provided. Years ago during the age of the land yacht manufacturers would specify low pressures to enhance comfort at the expense of handling even though this shortened tire life and made for some pretty mushy turning. Now due to suspension and tire design improvements this is not necessary for comfort. I believe it is done to induce understeer, the tendency for the front of the vehicle to slide, when pushed to it's limit of adhesion. While this is not a particularly good thing, it is better than the alternative of oversteer where the backend breaks loose first and comes around and gets in front of you, which is much harder to control. There is no doubt that tire pressure is a very critical component of driveability and safety, but there is room for tweaking that which is specified by the manufacturer so that some amount of personal preference can be addressed. BTW, pressure affects only the caster component of wheel alignment and caster has no effect on wear. It's the toe adjustment and the camber angle that cause the outsides or insides to wear prematurely. Underinflation will also cause the shoulders of the tires to wear quickly leaving the centers looking unused. That's because when turning, the shoulders tend to roll under and scrub, and when going straight the centers are receiving less of the load - just the opposite of overinflation.
Carlos: I have a very good and very old analog type guage, the type that used to be used in service stations when they were "service" stations. It is still accurate to about 1 psi.
Hope I haven't bored anyone with this long-windedness but it's Sunday here in paradise (Hobe Sound, Florida) and I haven't yet decided how to spend the day.
Enjoy your Sunday. I know what you mean having spent 10 years of my life in sunny Florida.
