SL/R230: What's happening with my lower bumper?
Old Nov 1, 2025 | 04:05 PM
mbates50's Avatar
2013 SL550 / 2006 XK8 / 2015 Triumph Bonneville/ 2019 C300 Cabroliet
Just noticed this. Can anyone tell me w what's causing this and is there anything I can do about it?
Thanks.
Old Nov 1, 2025 | 04:36 PM
PeterUbers's Avatar
Thanks.
exhaust heat - melting the plastic - have you been driving aggressively? Do you have a tune?
do you let it idle for a long time?
or did you just back into something (my #1 guess) and it's a one time dent/deformation - how does the other side look?
Old Nov 1, 2025 | 05:24 PM
mbates50's Avatar
no to all of the above, and haven't had it tuned since I bought it in 2015.
The dots are all uniform from one end to the other. Nothing appears to be melted, simply discoloring. If it was melting the plastic, I don't think it would melt it all the way to the end of the cover. The other side is exactly the same. It's 12 years old so I'm wondering if if the part is just starting to discolor. It's weird that they're all in a row.. I think it best to just take it to the dealer and see if they can explain it.
One thing though, I think that part was replaced when I was hit in the rear end . I don't know if that has anything to do with it
Thanks for your input
Old Nov 1, 2025 | 05:28 PM
PeterUbers's Avatar
So you're talking about the discoloration? That's just heat over time from the exhaust on the mesh common - circle what you're worried about to be specific
have you tried cleaning it with a safe tire/wheel cleaner? (Meguires hot wheels)
can we see the other side?
Old Nov 1, 2025 | 05:38 PM
mbates50's Avatar
see the photo
Looks like machine gun dings. Will try that...
Old Nov 1, 2025 | 05:43 PM
PeterUbers's Avatar
Oh now I see! That while speckled pattern - is that where the connectors are on the other side of that bumper piece - this is a defect in that piece and may need to be replaced entirely
was this car in an accident and non OEM bumper cover was used in the rear?
Old Nov 1, 2025 | 05:44 PM
PeterUbers's Avatar
How about a close up of this:
what ever this is it won't come off with cleaner
the whole piece likely will need to be replaced
Old Nov 1, 2025 | 05:46 PM
mbates50's Avatar
Yes, about 3 or 4 years ago. Dont know what Caliber Collision usec. Doubt is still under warranty anyway. Seems odd that there are that many connectors, tho.
Old Nov 1, 2025 | 05:49 PM
aegea's Avatar
2004 SL500AMG, 2003 SL500 USA
ask the body shop
Old Nov 1, 2025 | 05:51 PM
PeterUbers's Avatar
nothing odd about that - look at the diagram online of the lower valence - it has that many connectors
Old Nov 1, 2025 | 05:52 PM
mbates50's Avatar
Originally Posted by aegea
ask the body shop
Gonna have to or drive by dealer. Any reason to drive by Caliber who replaced it?
Old Nov 1, 2025 | 05:54 PM
mbates50's Avatar
Thanks. Would a paint job last. I have a guy who does excellent work on car bumpers...
Old Nov 1, 2025 | 05:57 PM
mbates50's Avatar
Any chance a paintjob would last.? I have a guy who's excellent fixing and painting car bumpers
Old Nov 1, 2025 | 06:15 PM
PeterUbers's Avatar
is the surface smooth? Sure - a good prep, prime and spray could last many years but I'm curious if there is a physical defect in that plastic
I think that's just a prefinished piece that when you order a new one it's already finished in that gun metal, that's my suspicion
so if you wanted to just finish that in an even a darker shade of gunmetal, it would look really good and you wouldn't have to spend as much money, you would be the only one that knew it was refinished because it would look perfectly fine to everybody else
Old Nov 1, 2025 | 06:19 PM
mbates50's Avatar
Smooth as a baby's butt!, No defects. And only where the connectors are.
Thanks for taking the time!!
Old Nov 1, 2025 | 06:21 PM
PeterUbers's Avatar
Old Nov 1, 2025 | 06:22 PM
PeterUbers's Avatar
Also, can you give us a closer look at at least one of those white spots?
Old Nov 1, 2025 | 06:26 PM
PeterUbers's Avatar
good prep, prime and spray will be fine for many years - cheers
Old Nov 1, 2025 | 06:32 PM
mbates50's Avatar
yep. I can see where all those dots came from now!,
Old Jan 10, 2026 | 07:12 PM
mbates50's Avatar
yep. Had it done. Good as new
