SL/R230: Super stiff ride
I know the ABC system pretty well, but heck does anyone know it completely?
Just guessing now, but this sounds like some type of limp mode.
What scanner are you using? Does your scanner allow you (besides Rodeo) to raise and lower each corner? Tried it?
Does your scanner show the voltages for the ride level sensors while you raise and lower each corner?
Does your scanner let you perform the ABC level calibration? This ties the strut position values to the ride level sensors so that the system will know if there is a inconsistency?
I wonder if this recalibration is necessary when replacing a strut. Still strange there are no codes.
Again just guessing and hoping someone has a more definitive answer.
and show data. I remember 193 bar, and some numbers in millimeters Pretty sure there were voltage outputs also.
On one side of the car as the height goes up the voltages go up, but on the other side as the height goes up the voltage go down. (Who the heck would design it this way.)
Look for an inconsistency from the voltages on the same side as the same side corners go up and down. Be sure you ride height sensor is connected and working correctly.
(I once had so much trouble figuring this out I bought a used set of ride height sensors just to be sure.)
Also, have you tried just disconnecting the rear battery for a few minutes to let all modules reset?
Level data in mm was also shown. There is some minor variation there. I am curious if mm level for front is supposed to be same as rear. The rear left is not same as rear right by 9 mm. I have attached some photos. Probably too much info.
i have not disconnect/reconnected accessory battery yet
IMHO, your rear values are different by 9mm in all positions with the right rear reading higher. Maybe that is why at level position the rear left check valve is at 24mA instead of 0mA.
IIRC the level values (in mm) are calculated from the voltages on the level sensors, not the plunger values. While the plungers (inside the shock) must also return a voltage, they are usually represented by a value between 0 (fully compressed) and 100 (fully extended). These plunger values show the true position of the corner. As I understand it, when the full calibration is done (which fully compresses and fully extended both the front and the back) by comparing the level sensor voltages to the plunger values, the system determines how to map level sensor voltages to level values in mm.
Complicated?? Seems stupidly complicated which might be why some people give up on the system. Why even have level sensors when you could just read the plunger values? Maybe the 2007+ ABC system is simpler in this way.
I learned all this when my ABC system went into fully raised, super stiff mode after replacing all the accumulators and flushing the entire system during my AMG engine swap. The Benz Ninja tried hard to help me, but all these voltages and values might have been beyond him too. So I experimented with both DAS and my Autel scanner until I understood more of it. But I still had an ABC "hard" code which would not clear. Researching the code, it could only be cleared by performing the full calibration. So obviously I tried that but it keep failing because the rear shocks would only extended to 98%, not 100. I made sure there was no binding in the suspension, even took some weight off using my hoist, removed the plungers from the shocks to check them, but it stayed at 98%. Meaning rock hard at full extension and the code would not clear.
Getting desperate, I bought two ABC controllers on eBay (maybe $60 each). Swapped one in, cleared some minor "soft" codes and everything works fine. I think one side is a bit lower than the other, but the ABC has been fine for thousands of miles. I'm hesitant to try the calibration again as a failure might give me a hard code. Well, at least I have yet another controller.
If you cannot solve this in the next few weeks, I will get values from my car. They might be off because it is not calibrated.
Good luck.
I have attached some screenshots that associate a voltage with pressure sensors. These seem to point also at right rear. Not sure if pointing at strut, calibration, or height sensor. Also attached are automatic calibration before and after. This can only run at neutral position. I will look some more, but I believe this is the only calibration adjustment my scanner offers. Do you know if front and rear struts are the same, esp. with regard to travel distance to top/bottom? Guess i could investigate this by checking if there is a different part no. for rear. Do you know if air induced while replacing accumulators/strut would naturally be removed by exercising level height and rodeo? Would air inhibit full strut motion?
So going forward, it seems i should do the following
1-scan the car for fault codes with a different scanner see what comes up
2-hard acu reset by disconnecting accessory battery
3-void all air from system?
3-eat pray think?
4-maybe replace right rear strut?
5-maybe replace acu?
I'll try to study your screens tomorrow night.
Please confirm that you successfully performed the calibration which raised and lowered the front and rear.
Your numbers look pretty typical to me, but I would like to see graphs of the acceleration sensors under different driving conditions. Also, I would check and make sure that all of them are mounted securely and have correct orientation. The 2.59V reading is a little off, but not sure if it indicates a problem. They are normally very close to 2.50 with the car stationary.
@MikeJ65 When I tried a full calibration it asked for the front and rear angles as you mentioned. Not sure what they were, I looked up "typical" values and entered them. Do you have info on how to actually measure them and/or what to enter? And how do they change the calibration?
While not "officially" for sale, the hardware is readily available as a Chinese clone on eBay and Alibaba. The software is readily available as a virtual machine which will run on a Windows laptop.
Many of us have paid the BenzNinja is set this up for us. He listed exactly what clone hardware to buy and needs a dedicated "clean" Windows laptop. He remotes into the laptop, installs the software and makes it all work. That laptop must NEVER be use for any other purpose.
The system is a bit non-intuitive to use, but BenzNinja will provide assistance. The laptop I bought for this was cheap and that is likely the reason it seems a bit slow.
I have found that my high-end Autel scanner does nearly everything, but would be too expensive for just this one application. I don't know how much lower priced scanners will do.
Working on very recent model MB is more complex as it requires an AutoAuth subscription account and an AutoAuth compatible high-end scanner.
Mike mentioned them because a defective one could make the system "think" you are in some unusual position which is best handled with a stiff suspension.
I have never looked at their signals, but presumably Xentry/DAS or a good scanner would should their output.
But now that I think of it, can ABC really stiffen the ride without affecting height? I'm thinking it can only raise or lower the corners, although a raised corner will ride stiffer.
I attached two screenshots taken while driving
i am curious about abc lateral sensor data, if sensor is faulty. I am curious why no sensor for left rear body when other 3 corners are shown.
I would expect the acceleration values to change as you drive; if one stays at 3.00V no matter what, IMHO that indicates a faulty one.
