SL/R231: My brakes squeak!
Old Apr 3, 2013 | 01:17 PM
red308's Avatar
2013 SL63
My brakes squeak!
Do your brakes squeak?
My brakes (the rear ones) squeak when I am doing a gentle stop at between 5 mph and full stop. If I step hard on the brakes they do not squeak.
I have the standard non-AMG brake package. Maybe that is what the issue is.
I am trying to determine if this is specific to my car or if others with this standard brake package are experiencing this problem.
In any case, I now have to take the car into the dealer to see if they can stop the noise.
Old Apr 3, 2013 | 02:09 PM
ajm0623's Avatar
'25 740i; '15 targa4s; '24 cayenne
yes! just as you describe. my 380sl and 560sl squealed like that, too, back in the 80s. maddening. but now i chalk it up to sl character! let us know what the dealer says as i am making a list of things that need to be reviewed by the dealer and want to knock them all off at once. if possible. nothing urgent, thankfully.
Old Apr 3, 2013 | 06:02 PM
PeterSL's Avatar
R231 SL500
Yep got exactly the same thing. Only once they are warmed up though. Took it to dealer 6 weeks ago but, of course, it wouldn't do it that particular morning. I can't be bothered going back as yet. Maybe I will do though, before roof down weather returns to the UK.
Old Apr 3, 2013 | 09:15 PM
California John's Avatar
2022 AMG SL63
I don't have the problem. But mine is the AMG wheel/brake package. I've had the car for almost 3 months. I too will be interested in what the dealer says.
Old Apr 14, 2013 | 02:23 PM
mikey94025's Avatar
2015 S550 Coupe
My breaks squeak too, but so do those on our 2009 Audi TT roadster. We reported the problem awhile back to Audi service but they said it was normal. Oh well... I just try to break a little harder now.
Old Apr 25, 2013 | 03:14 PM
Daytona-flyer's Avatar
AMG SLS & S coupe
Same here. No noise from with the AMG package.
Old May 3, 2013 | 02:08 PM
ajm0623's Avatar
there is a bulletin out for this problem. i just returned from the dealer and they performed the required check per the bulletin. basically, the mechanics are instructed to repair or replace the pads if required against standards. they check for proper installation and direction of pads and if found to be within spec, they grease and clean the pads. if they are found to be out of spec, they are replaced - all covered under warranty. no more squeal!!
aside and unrelated to the brake squeal issue, i see some others - like me - were getting an occasional "all meta data lost" in the comand screen on start up. but all operations of the car were normal otherwise. there is a comand software update available to the latest release/version for this problem as well. also covered under warranty, 'natch.
the entire set of fixes today took about 3h in total.
Old Jun 9, 2013 | 05:26 PM
Tezer's Avatar
Mercedes SL 550
no brake problems and no white problems,maybe I'm just lucky
Ted
Old Aug 1, 2013 | 02:49 PM
daveshatz's Avatar
1970 280SL 1985 380SL 1999 SL500
My brakes squeak until they become warm. Both my mechanic (an independent that works on my 280sl also) and a tire/brake shop I've used for years have told me this is normal. Anything they have done is only temporary. It's annoying to have people tell me that my brakes need to be replaced, I just smile and thank them.
Old Aug 5, 2013 | 10:52 AM
AMG SLS & S coupe
I did the update. Prior to the that, to temporally solve the meta-data lost, I reset the command unit. If you do that, be sure to save your settings. I think it's the bottom item on the same drop-down menu.
In the end, I cancelled the embrace package with internet service. It's too slow to be worth anything. I called MB and they told me it's due to the server being in Germany.
Thread creep??????
Old Aug 6, 2013 | 01:19 AM
2022 AMG SL63
I cancelled the embrace package also. Too damn slow and overall useless. MB is way behind on internet and user interface. Plus the maps and GPS usability is a decade old.
Old Aug 6, 2013 | 08:51 AM
Florida Joe's Avatar
2013 MB SL550
The NAV update fixed the "meta data file loss" message but Google maps on the iphone is just 100% easier and better.
I have the Iphone 4S linked to the car and use Pandora with Google maps if needed. Good integration. Not perfect but very good for my needs.
Old Aug 6, 2013 | 11:13 AM
AMG SLS & S coupe
My daughters new Dodge Dart has a better GPS then my Benz. A giant screen too. OTOH, The unit in the SL is much better than what I had in my '08 Z06.
I like going to "Send to Benz" http://mbrace.mbusa.com/send2benz and not having to screw with the GPS in the car.
Old Aug 6, 2013 | 06:14 PM
cloud's Avatar
R231,C43 Conv(W205)
Mine just started to squeak,car has 142 miles on it . I do not have the sport package or 19 inch wheels.Wait & see if they brake in or take it back to the dealer & ask them to review the SB?
Old Aug 7, 2013 | 06:23 PM
branmin's Avatar
Sold 06 CLS500. SL550 09. SL550 2013. Own C6 Corvette heavily customized garage queen 2005.
[QUOTE=Florida Joe;5739303]The NAV update fixed the "meta data file loss" message but Google maps on the iphone is just 100% easier and better.
I have the Iphone 4S linked to the car and use Pandora with Google maps if needed. Good integration. Not perfect but very good for my needs.[/QUOT
I have the 4..but can you please tell me how you intergrate google maps onto the screen?
Old Aug 8, 2013 | 08:38 AM
ajm0623's Avatar
cloud -- i had the brakes done per the bulletin i mentioned above in early may and now three months later not a peep at all. it worked. perfectly.
Old Aug 8, 2013 | 08:55 AM
cloud's Avatar
R231,C43 Conv(W205)
Did they just grease & clean or replace the pads? Do you or can you get the # of the TSB?
Old Sep 24, 2013 | 12:38 PM
mikey94025's Avatar
2015 S550 Coupe
It would be nice to know the exact TSB #.
I just had my 1-year service and also complained about the break squeaking. My SA first said that the noise was normal when I reported it and I had to push to get it looked at. But they still ultimately said that the noise was normal and not covered under warranty so the only improvement would occur if I paid to pay to have the pads replaced. I'm never impressed with the service effort at my dealership (San Francisco Mercedes Benz) so I'm not surprised that nothing got done.
Old Sep 24, 2013 | 07:24 PM
rogersar's Avatar
2017 AMG S63 Cabrio
my brakes would squeak with easy braking-dealer replaced pads-still squeak-they replaced pads and rotors-they no longer squeak
Old Sep 25, 2013 | 08:42 AM
cloud's Avatar
R231,C43 Conv(W205)
Does anyone have the TSB#
Old Nov 14, 2013 | 08:26 AM
cloud's Avatar
R231,C43 Conv(W205)
Has anyone been able to get the TSB #?
Old Nov 16, 2013 | 10:37 AM
r.schneidler's Avatar
SLss kk3Rcc 2350 SL 350
Hi, SL R 231-friends,
I´m from Germany, just for the next 5 weeks staying on Phuket (Thailand) for vacations. So I have time and enjoy your forum. The problem with the "squitchy" brakes (front) is also in Germany - with my SL 350 R231. I read it in the German forum for Mercedes Sl, and also I have the problem. But... not every time, also with slow driving and not permantly. I don´t like to drive to mercedes - they are so high sofisticated here... Do you know what I mean??? It is not a real problem for me - once a week and a little bit noisy.
Best regards
Achim
Old Nov 16, 2013 | 01:32 PM
cloud's Avatar
R231,C43 Conv(W205)
It seems when it gets cold outside they get worse.
Old Nov 21, 2013 | 05:05 PM
happyinboca's Avatar
2019 e 450 cabriolet
squeak too ... no loving it
Old Feb 17, 2014 | 09:46 PM
Car was in for another issue and I mentioned the brakes being squeaky - New front pads and rotors replaced by the dealer at no cost - no squeak since ...
