SL/R231: Centre Console Doors
Old Jul 21, 2018 | 06:58 AM
Silver_Spear's Avatar
R231 & W113
Hi guys,
For some reason, tried to open the centre console doors yesterday and only one of them flipped upwards.
Is this common for these cars? There is something related to the spring of the other door which is not working.
Tried to search the web for the correct way to remove this console and fix it, but couldn't find anything. Can somebody please share the procedure so that I can fix this?
Even detailed back side pictures help.
Danny
2013 Mercedes SL350
Old Jul 24, 2018 | 03:15 PM
R231 & W113
No one?
Old Jul 25, 2018 | 12:16 PM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
My new 2017 SL450 did the same thing when only 3 months old. Under warranty so the dealer replaced both sides as one unit. Took about 10 days to get the parts in....
Old Jul 25, 2018 | 02:10 PM
Piperkid's Avatar
2015 SL400, BMW Z3, Datsun 280Z, a couple of jeep Grand Cherokee's - And a Commander Airplane
I had the same problem and dealer replaced the mechanism. No problems since but I am fairly carefu with them
Don't know if the replacement parts are any different than the original.
Old Jul 25, 2018 | 10:44 PM
R231 & W113
My 2013 is out of warranty now, so no luck for me.
I am trying to find a writeup about how to remove it at least...
Old Jul 26, 2018 | 09:47 AM
rorywquin's Avatar
Shanks’s Pony
Unfortunately there are so few (relatively) SLs around that there is not a big knowledge base out there. I had a SLK and was a member of the SLK World and there is nothing those guys don't know about SLKs. I do wish we have something similar for the SL.
Old Jul 26, 2018 | 12:00 PM
Piperkid's Avatar
Unhappy Ditto
I also had an SLK and was active in the forum. Pretty active with a lot of knowledge.
Not so much here!
Old Aug 16, 2018 | 06:09 AM
R231 & W113
Any chance one can find an e-tech manual for these cars?
Old Aug 16, 2018 | 06:18 PM
The reason there is not a lot of repair knowledge on this forum, I believe, is that the vast majority of folks that can afford a 100k automobile don’t work on them.
Old Jul 31, 2021 | 12:24 PM
Xkeots's Avatar
2017 SL 450
Originally Posted by Silver_Spear
Hi guys,
Danny
2013 Mercedes SL350
I just got my 17 Sl back from service and only one side now opens. If any info out there, please share
Old Jul 31, 2021 | 01:00 PM
Unfortunately a known problem. I have had that same thing happen on both a 2008 SL 550 and a 2017 SL 450. Someone posted a fix for the spring quite some time back but then came in and said that it did not last and that the whole door assembly on both sides has to be replaced. Maybe somebody has some new information that is a little more positive.
Old Aug 2, 2021 | 05:06 PM
Jspann07's Avatar
2015 sl550 White Arrrowr, 2007 Jaguar xkr, Infinity QX 56
Try holding the button in while the driver side door is already open and gently lift the right side to open. Spray silicone on all parts and hopefully your good to go. Worked for me.
Old Aug 3, 2021 | 10:41 AM
Bitbytr's Avatar
'13 SL550 Mars Red, Designo White interior, B and O sound
USA LHD version here and the door nearest to the driver doesn't flip open: not stuck, just the spring mechanism nonfunctioning so no, silicone spray's not gonna do it.
Still searching for a fix...
Old Aug 3, 2021 | 10:44 AM
rorywquin's Avatar
Shanks’s Pony
Will this help?
https://www.youtube.com/channel/UCpd...IQhJcjW_j1jRPQ
Old Aug 3, 2021 | 11:28 AM
Bitbytr's Avatar
Whoa! In one. Thanks a lot.
I watched the videos and the guy, NorseViking, does a bang up job explaining and showing the process. He also demonstrates great skill and patience, two prerequisites I think I lack for this fairly involved task. I just picked up the car and this is the only defect I have found and, frankly, it is pretty insignificant and minor so I am predisposed at this point to live with it, I think.
Many thanks again!
Old Aug 3, 2021 | 09:01 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
Not so much here!
I agree there are fewer of these cars out there. I see very few on the road compared to r129 and r230’s
Plus, I believe the r231’s have proven pretty reliable with mostly minor issues for the majority of owners. (this has been the case for me).
I have already seen a few examples having 110-150k miles on Autotrader! There’s one on there right now with 136k. I’m willing to bet many owners of these cars don’t even have 50k on them yet. They are mostly 3rd cars for weekends or pleasure drives.
It will take time to build a knowledge base…
Old Jun 11, 2022 | 01:06 PM
Bay Leaf's Avatar
SL 350 R231
Mine's done exactly the same. So much for Mercedes being over engineered.
Old Jun 12, 2022 | 08:19 AM
spinalator's Avatar
2017 SL450 2022 GLC300
I purchased a used center console on e-bay and replaced the broken door. No problems since and its been over 2 years. I followed the U-Tube directions to remove and replace the center console door. It wasn't to bad.
Old Jun 12, 2022 | 02:57 PM
RonNSoCal's Avatar
2016 SL400 & 2021 C300
I have the same problem and the dealer refused to fix it under warranty while under a CPO extended warranty. My service tech reported Mercedes solution is to replace the whole unit for about $1200. I have learned to live with it. Turns out I rarely open it anyway.
Old Jun 12, 2022 | 10:20 PM
JettaRed's Avatar
Veteran: Army
That's nuts. Depending on the interior color, the doors (lids) run from $400 to $500 new. Replacing them should take less than an hour.
Old Aug 21, 2023 | 11:09 PM
rbrockett's Avatar
1997 SL500
The videos show in great detail how to remove the console lid, so thanks to the poster that mentioned NorseViking's YouTube stuff, and many thanks to NorseViking himself. A word of caution regarding replacing just the doors, and a couple of things of note:
  • I am not new to working on my cars and taking the panels off to get to the console was not difficult at all. I took my time and was overly careful so it took a bit to take it all apart, but if I have to do it again it will only take me a few minutes. I did not see any reason to pull the secondary battery. I would suggest being careful, but there is plenty of room to pull the rear-most clip out without going to that trouble.
  • NorseViking talks about the 'push-ins on the side panel fascia'. I was confused about the orientation of the panel from the video #11, so I misunderstood how the push-ins worked relative to the plastic hooks that slip in. For clarification, the side clips end behind the shifter and the push-ins work in the same orientation as the plastic clips. So once the side clips have been pulled out, pull the dash end of the panel backwards and the whole panel slides back and pulls off very easily. No pulling out at the bottom of the panel at the dash.
  • Now to the reason for my post. I was simply unable to remove the hinge pins that hold the lids on. I tried everything. I ruined three sets of needle-nosed pliars trying to get them skinny enough to get into the hole and to grab on the flats of those pins. I'm guessing it is possible, but I simply could not do it. Because of that, I gave up and chose to rebuild the broken spring pin hole with the lid still mounted. I put the spring back in and with the lid held open I loaded that area with the JB Weld made for plastics, let it cure, and then put on a second layer just for insurance. I also built up the same area on the other side that was not broken just as a precaution. For anyone else looking to make this repair, IMO this approach is easier than pulling the pins. Either way you go you still have to rebuild the pin hole boss, so I don't see the need to pull the lids off if you don't have to. In addition, I created a spring retainer by taking a washer with an ID the same as the spring mounting boss' OD, cut a key out so that I could slip it over the retainer pin on the spring mounting boss and then rotated the washer 180 degrees so that it would stay in place.
If anyone on here is thinking AT ALL about attempting this repair, by all means do it. It just isn't that hard. Watch NorseViking's videos, and you have everything you need to make this repair. Also, if anyone else on here has done the repair like NorseViking did, I would be curious to know just how you got those hinge pins out. They are a bear.
Old Aug 22, 2023 | 09:03 AM
spinalator's Avatar
I used a hemostat. It easily grabbed the pin and I was able to pull them out.
Old Aug 22, 2023 | 10:07 AM
rbrockett's Avatar
1997 SL500
A hemostat. Brilliant! I will keep that in mind if it should happen again. Thanks!
