SL/R231: ABC: Is noise during raise/lower normal ?
1986 560SL, 2017 E300, 2018 Sl550, 2020 E350
I'm re-posting to correct subject line (mistake in original ....ABS..... should have been ABC ...due to mistake probably did not reach correct audience)
Be great if some of you with ABC will perform a raise/lower operation and advise if you too hear what I hear as described here:
R231 2018 SL550.............When stationary if I cycle through a number of "raise and lower" operations I hear a slight "creaking" noise that follows the up/down movement.
Do others hear this as well ?
What might be causing it?
My dealers Hd Mechanic says "normal" but, the dealer doesn't have any other cars with ABC that can be compared only going by what he thinks is normal.
I sure would like to know if others hear what I hear and if not I want it fixed while the warranty is in force.
Steamroller and Wolfman have replied already in a general way but, sure would appreciate a few others to test and comment after testing.
THANKS in advance for responses.
Steve
Steve
Received 3,458 Likes
2020 S560 Sedan, 2019 SL450, 2019 E450 Luxury Trim Wagon, '24 BMW I7 on order...
Steve,
Today, I took my SL out for a drive and purposely raised and lowered the ABC several times, just for you. There were groaning and creaking sounds. As noted previously, my 2004 SL500 with ABC did this as well. As your mechanic stated, I do believe this is normal. If the raise/lower feature was used on a regular basis, like several times, every time you drive the car, it might go away, who knows? In the mean time, I am positively THRILLED with the performance of the wonderful ABC system and just love driving this car!
Best wishes,
StreamROLLER
Best wishes,
StreamROLLER
rorywquin (08-22-2019)
2013 SL550 (Lux Sport), 2006 CL55 AMG (Muscle). S550 (Wife's Sedan)
StreamRoller ...
Surely you must be referring to that 'groaning and squeaking', (but still wonderful), ABS system....
Steve,
Best wishes,
StreamROLLER
Best wishes,
StreamROLLER
Hi "STREAMLINER" (Much apology for calling you Steamroller in earlier post !!),
Want to THANK YOU for performing the requested test that shows you found the same noises I noticed so I now feel all is well with my ABC.
Like you I love the SL with ABC and don't see any other car to replace it (I don't want a soft top convertible so the new SL is out for me).
As of now I plan on buying out my car @ lease end.
My only concerns (always had them) relate to the long term reliability of the system based on the experience R230 owners have had with valve block rebuilds, failed hydraulic lines, accumulator failures ect so I will be buying the longest term Extended Warranty available.
Wonder what you and other R231 owners with ABC who plan to hold onto the car think would be a good "preventative maintenance" plan for the ABC system; I think this is needed as MB does not have a published plan to follow.
I'm thinking of the following:
1) Raise and lower sequence periodically to insure strut piston doesn't develop a non full travel shoulder that will damage the "O" rings but, how often...maybe once a month perform 3 or 4 cycles?
2) Fluid and filter chance (seems this will prevent crud build up in the valve block) but, how often.....maybe every 20K or 30K miles ?
3) Should a "rodeo" be preformed when fluid and filter changed or should a "rodeo" be performed only when a major component changed?
4) Accumulator replacement (the accumulator bladders seem to be the most likely part to fail based on constant pressure changes/movement and wear) but, how often.....maybe @ 50K miles F & R and pump accumulators as well should be changed?
5) I see that MB has changed the type "O" rings used in the R231 vs R230 to a better "O" ring material so trusting that the better "O" ring material and regular fluid and filter changes will assure long valve block life ?
6) As to hoses not sure what to expect ?
7) Any other thoughts?
Be great to get some thoughts/inputs from other R231 owners with ABC
THANKS, Steve
THANKS, Steve
Super Moderator
Received 3,178 Likes
THANKS, Steve
THANKS, Steve
Don’t know if the eight 231’s in the United States with ABC constitute a good sampling of reliability!
Super Moderator
It is a rarity but will be in the thousands over the years (approx. 7-8% of the roughly 26,000 US sales; same as B&O's). Any expensive option will be more rare but in my experience is that if a problem occurs, the forums will be the echo chamber for it. Bad news always travel faster.
A good point to bring up, and certainly reading the r230 forum could scare some away from ABC. But I still think the the scarcity of ABC problems posted here is a valid indicator that the system in the r231 with the 3 micron filter and other changes is more reliable than the original r230.
There were about 14,000 r231s sold in the US 2013-2019, with about half of those in 2013 and 2014. How many were equipped with ABC I don’t know, but very few maybe 1 or 2%? But all AMGs are ABC equipped. And ABC is standard in Canada, with sales of 1,500 units 2013-2019. Then there’s MBC, the same suspension with a camera, introduced in the S Class in 2013 as an option. S class sales from 2013-2019 were 117,000. How many were built with MBC again, I don’t know, but it wouldn’t take a very high percentage to give you several thousand vehicles. So altogether three thousand cars at least. Not very many still, and a seven year history is not a long one, but still I think its enough that I wouldn’t let the r230 ABC problems deter me from getting it on an r231 if I wanted that option.
Agree with Wolfman, who got his post in while I was still writing mine - bad news seems to get amplified in a forum setting. By the way, how many posts do I need to submit before ditching the “Junior Member” label?
Super Moderator
2019 1047
2018 2126
2017 2940
2016 3722
2015 4060
2014 5030
2013 7007
Super Moderator
Probably 100? But no worries, nothing "junior" about your contributions
Thanks for the correction. I got the figures from carsalesbase.com and did a quick sum but somehow typed a completely different number.
And it turns out the answer to my question is 75!
