SL/R231: Key Fob Batteries...
Old Sep 29, 2020 | 11:36 AM
Utopia Texas's Avatar
2019 SL550/2023 EQS 580 SUV
Has anyone had any problems with any particular brand of battery in the key fobs. I received a message on my dashboard A few weeks back that I need to replace the battery and I did it in both key fobs and after about four or five days the SL tells me to replace the batteries again. Is there a particular brand that is better than the others? 2019 SL 550 Thank you
Old Sep 29, 2020 | 11:52 AM
hornethandler's Avatar
Veteran: Canadian Forces
2019 SL450; 2023 M850i coupe
I don’t have any data to verify, but in my experience it’s best to steer clear of Asian branded batteries and stick with name brands, e.g., Varta, Duracell, Eveready.
Old Sep 29, 2020 | 11:53 AM
Patric's Avatar
14 E63S Wagon, 16 GTS Edition1 (Sold), 17 SL450 designo edition
I had some similar problems several months ago and asked my MB service adviser about it. He said MB had recommended they use Panasonic battery’s with no reason given. So far I’m having no more problems.
Old Sep 29, 2020 | 11:54 AM
allfortheunion's Avatar
2020 SL550. 2018 E400S4. 2014 CLS550
Check with your dealer. The guy behind the parts counter at mine replaced the battery and remarked offhand that for unknown reasons one brand worked much better than others. Can’t remember which brand it was, though, sorry.
Old Sep 29, 2020 | 12:00 PM
tx170754's Avatar
S560/SL550/LS460/Q70L 5.6 AWD
Do you get the message when using both keys or only from one ? I usually replace batteries on all the remotes of the cars I have using batteries from Batteries Plus, never had a problem. If you get the message from both remotes then probably the batteries were some poor quality, if you get the message from only one remote it may be that specific remote, switch the batteries and see if the problem persist, that is my opinion.
Old Sep 29, 2020 | 04:24 PM
docsout's Avatar
2023 S Class 2013 SL
Local dealer parts man says, Panasonic.
Old Sep 29, 2020 | 05:07 PM
rmorin49's Avatar
Veteran: Army
2015 SL400; 2019 X5M40i
It's likely the age of the battery. These batteries will lose potency just sitting around. Amazon buyers constantly complain about outdated batteries being sold on Amazon.
Old Sep 29, 2020 | 06:32 PM
WN1X's Avatar
2013 SL550, 2017 GLE350, 2018 Audi Q3
I agree...those silver oxide batteries do not age well. Buy your batteries from some place that go through a lot of stock.
Old Sep 30, 2020 | 09:21 AM
FIGHT BOSS's Avatar
Bentley Continental GTS / SL 550/SL 63/Dodge Charger/RAM Truck/2021 Genesis GV 80
I use the Duracell 2032 (I believe). No issues at all.
Old Sep 30, 2020 | 01:23 PM
threeMBs's Avatar
Only MBs - the best or nothing
The number is 2025. MB uses Panasonic.
Old Oct 1, 2020 | 07:35 PM
branmin's Avatar
Sold 06 CLS500. SL550 09. SL550 2013. Own C6 Corvette heavily customized garage queen 2005.
Duracel 2025 lasts longer than the 2032 and fits better. Never had the Panasonic but if I see it around will try them.
Old Oct 2, 2020 | 09:05 AM
ygmn's Avatar
2015 E400 Sedan
I have has issues with all makes and models of coin batteries
I think it is due to them not being used much so they sit on shelf too long and they do not like sitting doing nothing so they give up electrons...
Coin batteries = Ultimate Gambling!
SO buy plenty
Old Oct 2, 2020 | 09:24 AM
Piperkid's Avatar
2015 SL400, BMW Z3, Datsun 280Z, a couple of jeep Grand Cherokee's - And a Commander Airplane
I have had good results with Amazon Batteries - Just keep them in the refrigerator until needed.
The other trick when the car is sitting idle - lock the car and then press the lock button a second time so the remote is not constantly communicating with the car.
Old Oct 2, 2020 | 09:29 AM
rmorin49's Avatar
Veteran: Army
I used to store batteries in a cold place but there is no evidence this helps prevent slow discharge. However, they should be stored at "room temperatures". Hot environments will speed their discharge.
https://www.usatoday.com/story/money...ct/4062734002/
Old Oct 2, 2020 | 11:22 PM
Piperkid's Avatar
Smile Batteries
I live in AZ - The only cool place is the refrigerator
Old Oct 4, 2020 | 11:25 AM
Bay Leaf's Avatar
SL 350 R231
All good advice but how do you actually change them, pics would be handy.
Old Oct 4, 2020 | 12:11 PM
There is a small manual key hidden in the fob in case the battery goes dead to open the car door. You press on a tiny button on the fob and pull the key out, turn it around backwards and insert into the fob and the whole side cover will pop off. Take out old battery, insert new. Pop cover back on and insert key back into fob the correct way. Done...
Old Oct 5, 2020 | 11:55 AM
Bay Leaf's Avatar
SL 350 R231
Thanks for that UT but it didn't work
Old Oct 5, 2020 | 12:26 PM
WN1X's Avatar
What part of the instructions didn't work?
Old Oct 5, 2020 | 01:06 PM
Either look it up in your manual or take it to your local MB dealership and they will do it for you.
Old Oct 5, 2020 | 01:56 PM
Here you go...
