SL/R231: Pre-safe Functions Limited
Has anyone here had this happen to them? Car is a 2016 SL400 with 20,000 miles. TIA.
https://xenons4u.co.uk/blog/mercedes...rators-manual/
Thank you. I also found that when I searched but I was hoping to find someone here with 1st hand experience with it and what the result was. Certainly appreciate your help though.
I stopped by my local indy shop this morning. Tech said he has seen this problem before and it’s usually the battery. Have an appointment in 2 weeks to take it in (I’m leaving tomorrow for 10 days).
There will be folks here that will say you NEED to get an SDS/Xentry clone from China, but while I have that, it's a lot more cumbersome to set up and use. The iCarsoft tool fits nicely in the storage behind the driver's seat along with the owners manual, so you always have it with you. For more functionality, I have an Autel MaxiDAS DS808K, though it's more pricey than even an SDS clone.
EDIT: While I remain convinced every Benz owner needs to have in the car a Benz-specific scan tool (not a generic OBD reader), I have changed my opinion of also having XENTRY with the C4 multiplexer IF you need to actually repair and reset an electronic fault or event.
And if you have multiple cars, it may be a good fit to get a "jack of all trades - master of none solution". Also if on a budget and working on your $120k car, that may be a good solution too.
Your software may be incomplete as I know you had a hard time finding the parts you needed for your trunk lid hydraulics. It took about 5 minutes to find it in my version of the EPC.
https://mbworld.org/forums/sl-class-...ine-leaks.html
Here's a couple HHT's that recently came up:
Mercedes GENUINE HHT #1
Mercedes GENUINE HHT #2
You mean the Chinese clone version right?
Can you elaborate what is "more cumbersome to set up and use"?
Here's the procedure for scanning your car in XENTRY
1) Hook up your OBD-II cable to your OBD-II port
2) Switch to ignition position 2
3) Click on diagnostics icon
4 ) Enter your VIN (skip step 5 if you previously checked "automatically start quick test on completion of VIN")
5) Click on continue
Test runs
Gives results
Now you can dig down and it will give you much more data than you can get in any other third party solution. Including part numbers of the defective items as well even a software revision/firmware of electronic parts. There's a reason why dealers and competent independents (with PassThru ) use this software day in day out. Because READING codes is half the battle. TESTING components is the other half. That's where ALL third party solutions fall short.
If you have multiple Mercedes vehicles, especially vehicles that used HHT. Setting things like ride height in ADS and ADSII you will be SOL. Sure you might read the codes but can't do anything to correct your issues. Rodeo functions on ABC are also a no go. There are SO many things you CAN'T do as a tech, that it makes no sense to invest in anything else, Especially if you specialize in MBZ cars or maintain a fleet.
Maybe your version has issues or is incomplete as I mentioned above. There are many different grades of clone cables or maybe your multiplexer has issues, I'm not sure but like any other tool, the more you use it the more proficient you become with that tool. Since it seems you prefer to use your iCarsoft, maybe your comfortable with it. And that's OK. But the more you use it the less cumbersome it will become. The reason it may feel cumbersome to you is it's VERY DETAILED.
I'm very comfortable with XENTRY because I use it exclusively for Mercedes vehicles.
I completely agree that one must get the best tool they are comfortable with, but believe you're underestimating the mechanical aptitude of many of the posters here. I know several are mechanical engineers, highly experienced mechanics, and others, masters of their craft in different industries. So if they do want a complete solution and only work on Mercedes cars, it may be a good fit for them. To call the system "cumbersome to set up and use" is selling those people short and giving them false hope that they will be able to carry out diagnostics AND TESTING in anything other than the factory solution of XENTRY. If they want to read codes and then bring it to the dealer for repairs, that's an entirely different user....
I've included some pictures below just to help folks understand the difference in details available between other systems and XENTRY. This is just in "quick testing".
Each one of those sections (with the + box) you can dig down to get hardware version, firmware version, part numbers, time of and frequency of faults and cross reference many other data fields.
I'm happy to report my car has no codes stored!
Hope that clarifies some confusion.
Cheers.
The problem I had with finding the part I needed was that I was looking in the wrong place. I was looking at trunk lid parts instead of roof parts. Whoda thought to look in the roof group when the problem was with the trunk hydraulics? 🤪
I try to approach things from a very objective viewpoint. These are complex cars, hence It’s important to try to stay as technically correct as possible. I also feel It’s important for people reading these posts now and even in the future to understand the difference in the scanning software available to them. But it has to be presented as unbiased as possible. Which is my point in that post. XENTRY IS the factory software made to communicate with our cars. There is no substitute. Pretty simple. It’s not complicated to use, but requires familiarity like any other tool. That tool is comprised of several key components which must meet some strict standards so it can be assembled properly and used reliably.
As I said above, it’s important to stay as objective as possible when describing tools others may need to fix and test their cars properly. Especially if they own cars that use HHT or need diagnostic as well as code reading functionality. But in the end it’s THEIR choice and that’s OK. But you can’t present something as a substitute, when it’s not. That being said, there is validity in the fact that it is an inexpensive, easy to carry scanner. It fits a nice niche just to scan for codes and is much better than a generic code reader or “winging it”. I absolutely would recommend it to someone who needs that function.
Cheers.
Thanks @crconsulting for taking the time to post your thoughtful responses.
Absolutely, though mobile, the STAR Diagnostic system is designed for a workshop environment.
Nobody should be “arguing” anything. It’s just a presentation of accurate facts that will enable people who may be interested or need to use these tools to make a decision of what is best for their particular needs.
Cheers.
To that effect I recently found out how to get more of what we like:
subscribe to select members!
Once you have the right way to understand things its becomes fun to learn more, nice & easy
- Thank you!
