SL/R231: Anyone running a front license plate?
Old 05-09-2016, 09:11 AM
gkgeiger's Avatar
'10 C300, '15 ML250BT, '22 M850i Vert
My dealer just called to ask if I wanted the frt. license brkt. installed. Ohio is a two plate state but some people with sports cars take the chance and don't install it. I assume there are holes to be drilled. Does anyone have a picture with one installed. Thanks,
Old 05-09-2016, 10:57 AM
Plutoe's Avatar
Received 1,045 Likes on 968 Posts
1999 E300TD
If you live in a two plate state you will be ticketed if only one plate----and yes holes are drilled in the bumper for he front plate holder----however as you know FL is a one plate state and I would recommend you leave the front plate holder on the bumper if and when to register in FL----FTP!!
Old 05-09-2016, 12:40 PM
Super Moderator
Wolfman's Avatar
Received 3,276 Likes on 2,037 Posts
Don't have it drilled!
It looks like crap.
You can always take a chance and drive without a front plate; I did for many years but then hit a streak of getting ticketed for it.
So instead I found a cheap and Great (IMO) way of installing the plate without drilling. Looks better too.
Here is a link to the old posts...
https://mbworld.org/forums/sl-class-...ate-mount.html
Old 05-09-2016, 01:27 PM
gkgeiger's Avatar
It looks like crap.
My C7 came with 2 different brkts. neither one required drilling. I think your set up will work for me. Thanks
Old 05-09-2016, 08:26 PM
greatkoei's Avatar
'13 SL550
It looks like crap.
Thanks for mentioning that mount. Since I have a customized front camera installed, I think I'll take my chance to not have a front plate. Even with the mount, the plate would still cover my front camera Any suggestions?
Old 05-09-2016, 10:42 PM
bbirdwell's Avatar
'99 and '05 E55 AMG
Once upon a time, on the return leg of a 5000 mile road trip, I was stopped by a State Trooper for no front plate, and I asked him, "Why is it such a big deal?". Trooper Diaz then explained to me that it provided him "probable cause" to pull a car over. He told me that he then runs the driver for warrants, smells for alcohol or marijuana, judges if the driver or passenger(s) are high on illegal drugs, which then gives him additional probable cause to search the car for illegal weapons, drugs, or contraband. He intimated he was quite successful following this model.
FWIW, he instigated the stop in a confrontational mode, then dropped down into a back-and-forth mode, then into a conversation and we parted rather amiably. I learned quite a bit with that one traffic stop.
And I installed the front plate as soon as I returned home.
Old 05-10-2016, 12:15 AM
Super Moderator
Wolfman's Avatar
You can still mount it lower than I did; just below the camera. The setting is adjustable. I just preferred it to be as flush against the grill as possible so this was the best position for me.
Old 05-10-2016, 12:21 AM
greatkoei's Avatar
'13 SL550
Looking at the pictures of your plate, I don't see much space under. I measured against the grill using my own plate, and sadly it wouldn't fit straight-up. The only way is to tilt it, which looks quite awful.
Old 05-10-2016, 12:28 PM
Super Moderator
Wolfman's Avatar
I think you misunderstood. The license plate would be straight. If you look at the attached image, you see that there is a 1" long metal piece that connects the bumper and license plate mounts. By loosening the screws, the license plate moves forward/down to make space for the camera and clear the lower lip.
Less ideal but there aren't a lot of options if you need a plate mounted. There is of course the ugly tow hook mount where the the license plate sits on one side over the tow hook cover.
Or you could move the camera into the grill or off-center.
Good luck!
Old 05-10-2016, 03:27 PM
greatkoei's Avatar
'13 SL550
The problem I am seeing here is that the camera isn't facing exactly straight front, but rather facing a little downward to detect any curb. Even if the plate is mounted an inch away from the grill, it would still kind of block the camera view. Another option is like what you suggested, move the camera to the side, but that would require another cut on the grill, as well as having an angular image since the grill isn't flat. Anyways, thanks for the tip. I guess I'll buy the mount and give a try. Worst case, I'd install the plate off center.
Old 05-10-2016, 04:36 PM
Super Moderator
Wolfman's Avatar
You maybe overthinking this. Cameras are wide-angle and the install as suggested shouldn't impede any field of view.
Try the mount; it's $20 purchase at most...
Old 05-10-2016, 07:12 PM
gkgeiger's Avatar
Ordered one today. Don't want to take a chance without a front plate. Thought I might be able to modify the Vette Brkt. but couldn't make it fit. Similar contour but not close enough.
Old 05-10-2016, 11:55 PM
Super Moderator
Wolfman's Avatar
I think you will like it. It' very minimalist and flush with the lower bumper grill.
Just FYI, I just used 2 long stainless machines screws with a large washer (1" or so) assemble all without the license plate and then just push the washers through the grill. Just tighten and you are done. The washers become the back plate.
Took 20 minutes of which most time was spent to replace the factory screws with stainless steel ones. Zero rust after 2+ years.
This is required if bad weather is involved otherwise it will rust.
Old 05-23-2016, 02:54 PM
gkgeiger's Avatar
Well, I rec'd the brkt. from Amazon but didn't care for the fit. So I took the backing that I used on my Vette and made it fit the SL. I had already installed 4 threaded inserts to attach the plate with stainless machine screws. I had my dealer order me a second grille mtg. brkt. (one came with the car) that cost $27 but should be $2 (see 1st pic). The backing contours the grille perfectly and looks much better than the stock one, and if I ever sell the car it can easily be removed.
Old 05-27-2016, 10:57 PM
rogersar's Avatar
2017 AMG S63 Cabrio
I just fastened the front license plate using the Mercedes supplied plastic piece and no drilling in the bumper. I used 3- 1/4"x 2" round head stainless screws, fender washer, lock washer and nut. I inserted the assembled screw in the plastic license backer with the washers and nut through the grill. It took some effort to get the fender washer through the grill, but it worked quite well i think.
Attached Thumbnails Anyone running a front license plate?-2016-05-27-18.49.39.jpg   Anyone running a front license plate?-2016-05-27-18.37.49.jpg   Anyone running a front license plate?-2016-05-27-18.38.46.jpg   Anyone running a front license plate?-2016-05-27-18.49.53.jpg
Old 06-01-2016, 06:12 PM
Green_Hornet's Avatar
1855
As far as I'm concerned, Sports Car = NO front plate. No way, no how.
I'd rather pay the fine.
videopho (12-25-2023)
Old 06-28-2016, 02:44 PM
Mulepick's Avatar
2013 SL 550
NV is a two plate state but does not require a front plate if the vehicle came fm the manufacturer w/o provisions to hang one. My CPO came fm NC, a one plate state, so I don't run a front quite legally.
Old 11-29-2023, 11:17 AM
tdc03's Avatar
SL550
Hi Greg, I know this post is a little dated, but I was wondering if you had the actual part number for the little bracket that attaches to the grill...
Old 11-29-2023, 11:23 AM
tdc03's Avatar
SL550
anyone have the MB part number for this bracket that comes with the license plate holder?
Old 11-29-2023, 05:04 PM
TomZVB's Avatar
R231 SL 63
Here in Virginia you’re supposed to run a front plate, but being in VB, were so close to the NC border, that no one really looks or cares.
Haven’t run a front plate on anything for years. Probably jinxed myself, but I’ll just pay the ticket.
Old 11-29-2023, 05:47 PM
tdc03's Avatar
SL550
I'm in NY and front plates are required to pass inspection. We just got the car and it doesn't have a front plate mount so we're looking for options. These 'clips' and bracket seem to be a solid choice to mount a plate to the lower grill opposed to nuts and bolts. Just can't seem to find a part number or where to get them.
Old 11-29-2023, 05:50 PM
tdc03's Avatar
SL550
it looks like GKGEIGER bought extra clips from a Mercedes dealer back in 2015 (based on his previous post in this thread) but I don't know how to contact him directly to see if he has a part number or what exactly he purchased.
Quick Reply: SL/R231: Anyone running a front license plate?
