SL/R231: Unexpected Consequence of installing CarPlay Kit
Old Apr 13, 2022 | 02:47 AM
JettaRed's Avatar
Veteran: Army
So, I installed the Road Top Wireless CarPlay Retrofit Kit in my 2015 SL400. It gives me the features I wanted but I'm still exploring things. One of the consequences that I noticed was how much better the sound is from the factory speakers. I was not expecting that.
One problem I'm trying to figure out is why do I lose my radio sound (and internet connection) when I move out of range of my home network. Why doesn't the internet connection switch to cellular? I'm still working through that. If anyone has installed a CarPlay kit and figured this out, please let me know.
Old Apr 13, 2022 | 07:28 AM
jrupp's Avatar
2013 SL550
How difficult was the install? Are you happy with it?
Old Apr 13, 2022 | 08:03 AM
JettaRed's Avatar
Veteran: Army
I am happy with it. It works well. The settings to use on the dip switch are for the 7" display. Once I figure out how to get music from iHeart (or any other streaming music service) while driving, I'll be done. but I think that's a problem with how I have things on my phone and not the CarPlay kit.
Installation is a bit of a bear when trying to fit everything back together. There was no way I could squeeze everything in where the radio goes, so I put the decoder in the glove box. There is actually a square knock-out on the left if you look closely. The other thing is the big connector I had to push over to a space on the left side by the driver's foot well. With some maneuvering, I was able to get everything to fit.
Old Apr 13, 2022 | 09:12 AM
Wolfman's Avatar
Super Moderator
It appears that you are connected to your home Wi-Fi network instead of the one from the CarPlay adapter. Happy to hear that it’s working out for you!
Old Apr 13, 2022 | 09:24 AM
JettaRed's Avatar
Veteran: Army
Once I set the music service to use cellular on my iPhone, the music problem is solved. Now I just need to figure out the reverse camera.
Old Apr 13, 2022 | 09:59 AM
JettaRed's Avatar
Veteran: Army
Well, got the camera figured out. I always helps to read the instructions. 😝
Old Apr 13, 2022 | 10:02 AM
JettaRed's Avatar
Veteran: Army
The big connector goes behind the plastic part.
Picture of glove box with cables thru the knockout.
Old Apr 13, 2022 | 10:09 AM
jrupp's Avatar
2013 SL550
I watched a video where the guy dropped the glove box and there was plenty of space to mount the car play unit out of sight. How long did it take you and do you think an average DIY'er could handle it?
Old Apr 13, 2022 | 10:38 AM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
Good Job!
There should be.
Old Apr 13, 2022 | 10:42 AM
JettaRed's Avatar
Veteran: Army
I did it in about 3 hrs, I guess. But I'm retired so I don't have a watch.
I just took my time since I was in no rush. Good point about dropping the glove box. I may try that if I don't like the decoder in the glove box. My only concern with where he put it next to the airbag is would that become a projectile if the airbag ever deployed.
Old Apr 13, 2022 | 10:48 AM
JettaRed's Avatar
Veteran: Army
The dip switch settings I used are 3, 6, and 8 on.
Old Apr 13, 2022 | 12:17 PM
JettaRed's Avatar
Veteran: Army
I ran the AUX cable and iPhone cable along the center console and drilled a couple of holes.
You need to remove the armrest top to loosen the connectors “box”. Then you can drill holes. I drilled ⅜” holes.
Old Apr 13, 2022 | 12:21 PM
JettaRed's Avatar
Veteran: Army
By the way, I can actually hear the rear speakers. CarPlay has a built-in equalizer the I think makes the difference. That alone is worth the $300.
Old Apr 13, 2022 | 12:49 PM
jrupp's Avatar
2013 SL550
Good to know. Does the rear camera work? Nice work, by the way.
Old Apr 13, 2022 | 01:48 PM
Wolfman's Avatar
Super Moderator
That would be required anyway. Didn't you use the phone to listen to music before via BT or USB?
Also, I used to remove the glovebox in prior radar/Dashcam installs. Super easy as you already have the side panel off; I think its just 4 screws...
Old Apr 13, 2022 | 01:55 PM
JettaRed's Avatar
Veteran: Army
Thanks. Yes it does. But it is important to follow instructions.
Old Apr 13, 2022 | 01:57 PM
JettaRed's Avatar
Veteran: Army
And it is important to ground the audio correctly. If not, it's all distorted.
Old Apr 13, 2022 | 01:59 PM
JettaRed's Avatar
Veteran: Army
I should have gone back and watched the video. I removed the four screws, but it wouldn't budge. That would certainly make it easier. (Also, having the top down made it easier, especially when getting behind the seats to remove the armrest top.)
No, never did. I had regular radio and satellite radio in the car before.
