SL/R231: Center console not opening
Old Jun 10, 2022 | 04:42 PM
rorywquin's Avatar
Shanks’s Pony
Originally Posted by griza
Thanks saw that one - hacks tabs off with tin snips. I have mine out and know that if you remove the side panel (immediately to the rear of the door) it is easier. Was hoping that there is a short cut that does not involve tin snips or removal of side panelling and the right rear speaker.
Old Jun 10, 2022 | 05:32 PM
Sunbeltgolfer11's Avatar
E63s SL550 GL450
Originally Posted by JettaRed
That's why I asked what kind of "extended warranty" it was. I don't know but assumed that MB extended warranties were what CPO cars carried. However, that could be a totally bad assumption. Seems to me that if you pay $5000-$6000 for an "extended warranty", you would get something like this covered. That whole top piece is easily replaceable. I can't see where it would cost $2400.
There's one on eBay for $245, but the spring is broken. Hmmmm, sounds like a common problem.
He verified that it it is the Mercedes extended warranty. Dealer is still claiming it isn't covered. He is appealing to the owner. Thanks for the replies, they have been helpful.
Old Jun 10, 2022 | 05:34 PM
E63s SL550 GL450
Originally Posted by crconsulting
This is a fairly common issue with R231’s
https://mbworld.org/forums/sl-class-...ole-doors.html
https://mbworld.org/forums/sl-class-...-pop-open.html
$2400 is one zero off from the $240 this repair should cost ☹️
Your hinges need to be replaced or repaired. I believe there is a video detailing the process on here.
https://www.youtube.com/user/NorseVikiing/videos
next time I’m in the EPC I’ll upload the procedure from MBZ
Thank you. I will forward this to him. He has priced the parts and looked at some tutorial video in case he has to tackle it himself. Situation seems so unnecessary..
Old Jun 10, 2022 | 06:13 PM
crconsulting's Avatar
2020 GLC300 -2014 Sl550 - 1997 SL600
Originally Posted by rorywquin
Is there a procedure to remove the battery behind the right side seat?
@rorywquin Attached is the WIS section for Aux Battery R&R. No magic bullets (shortcuts), but may help….
File Type: pdf
Old Jun 10, 2022 | 06:16 PM
Attached is the WIS section for R&R of center console/armrest.
May help him if he tackles the job.
File Type: pdf
Old Jun 11, 2022 | 08:46 AM
E63s SL550 GL450
Thank you. I'll send it to him. He's not making much headway with the dealer so it looks like either an independent garage or he he tackles it himself.
Old Jun 11, 2022 | 09:03 AM
  #32
JettaRed's Avatar
Veteran: Army
The WIS procedure pictures look confusing if you've not done this before. I removed my armrest assembly when installing the CarPlay unit and running cables to the AUX port. Removing the armrest is about a 10 minute job. I haven't read the step-by-step instructions yet, but it's not a tough job.
Old Jun 11, 2022 | 10:40 AM
  #33
rorywquin's Avatar
Shanks’s Pony
Thanks for that. Yea they show the right rear speaker panel removed.
Old Jun 11, 2022 | 11:01 AM
  #34
I agree, I think the videos I linked are more helpful. The WIS section is for R&R of the whole console. Typically when they don’t have a breakout section for R&R of a part, it should be pretty self explanatory on removal. I think last time I ordered one of those armrests it was around $350. OP’s friend should check his VIN before ordering part to confirm fitment.
I have Part # 231 680 79 01 9H15 (Black)
(edit). Looks like about $390.00 or so now. https://www.buymercedespartsnow.com/...iABEgKckPD_BwE
Old Jun 14, 2022 | 10:43 AM
  #35
E63s SL550 GL450
Thanks for the input and help. He is getting nowhere with the dealer and EW. He has found a local independent and is planning to take it there for the repair. I've forwarded the info provided here and although he feels he could do it, doesn't want to take it on.
Old Jun 14, 2022 | 11:11 AM
  #36
JettaRed's Avatar
Veteran: Army
I would certainly seek a refund on the EW and talk to Trent at @Highline-Autos and see what he can offer. Some plans have a wait period, but I think Fidelity has immediate coverage. Not sure any plan he has will cover this particular problem since it is pre-existing, but if this is just a sample of the kind of service the MB EW plan gives, he may really want to shop around.
